..restoring discolored plastic #1488435
08/21/13 05:03 PM
08/21/13 05:03 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..anybody figured out how to restore discolored plastic
back to a new white appearance.
..Have a nice '73 coolant overflow reservoir i'd like
to use.
Re: ..restoring discolored plastic [Re: can.al] #1488436
08/21/13 06:26 PM
08/21/13 06:26 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
Scrub with purple power and or soak in bleach if it is just surface discoloration. I suspect your are referring to age yellowing though, never heard of a way to reverse that in my years around cars.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: ..restoring discolored plastic [Re: Michael Ecks] #1488437
08/21/13 07:19 PM
08/21/13 07:19 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Only thing I've personally used that worked good on white or clear is soaking in hydrogen peroxide out in the sun full strength.
Re: ..restoring discolored plastic [Re: can.al] #1488438
08/22/13 11:59 AM
08/22/13 11:59 AM
Helsinki, Finland
Anselmi Offline
Anselmi  Offline
Helsinki, Finland
I found this a while ago -> http://retr0bright.wikispaces.com/home
Wondering if the different plastics found on Mopars would react similarly....
'66 Plymouth
'64 Dodge
'63 Plymouth x 3
Re: ..restoring discolored plastic [Re: Anselmi] #1488439
08/22/13 02:41 PM
08/22/13 02:41 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..very interesting!
Re: ..restoring discolored plastic [Re: Anselmi] #1488440
08/22/13 05:56 PM
08/22/13 05:56 PM
Columbus, GA
Columbus, GA
interesting. I note the primary ingredients are peroxide and a UV lamp, similar to what the previous poster was on to with peroxide in sunlight. I'm skeptical about it on this application though. All of the pics from the wiki site are from opaque computer parts, whereas something like an overflow or wiper fluid tank is translucent in nature. Not sure how the peroxide could change the color of the plastic below the very surface.
would be an interesting experiment though.
