Best 440 headers for 4spd clearance??? #1487235
08/20/13 04:56 AM
08/20/13 04:56 AM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Had TTIs and was a bear for the linkage clearance. Any better headers or a opinion on a shorty header setup??? Going to build a 490-ish stroker with EB heads. Running a 6-pak setup too.
Any thoughts?
Re: Best 440 headers for 4spd clearance??? [Re: Fasbird] #1487236
08/20/13 08:21 AM
08/20/13 08:21 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
I just installed Hedman headers and had/have 0 issues with 4-spd linkage clearance. I did have to dimple the tube next to the power steering pump though. I have a 440 in an E-Body...
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Best 440 headers for 4spd clearance??? [Re: Plum440] #1487237
08/20/13 02:33 PM
08/20/13 02:33 PM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Thanks for the response.
I'm going in a '71 RR, so they should be close to the same as far as the engine compartment and K-frame room. How about the flange? Is it thicker like the TTI's? Do you have a model number?
Thanks!!!
Re: Best 440 headers for 4spd clearance??? [Re: Fasbird] #1487238
08/20/13 03:57 PM
08/20/13 03:57 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
I don't care how much they cost..Ive put headers on a hundred cars and have NEVER seen quality and solid construction like I have seen with a full TTI system...Im sold for life.
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Best 440 headers for 4spd clearance??? [Re: 72N96RR] #1487239
08/20/13 03:57 PM
08/20/13 03:57 PM
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
a nudder
Re: Best 440 headers for 4spd clearance??? [Re: Fasbird] #1487240
08/20/13 04:33 PM
08/20/13 04:33 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I just fitted Doug's 2" headers to my stroker. They fit like a glove, no dings required and it's an 18 spline 4 speed with an 11" clutch.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Best 440 headers for 4spd clearance??? [Re: Mick70RR] #1487241
08/20/13 05:49 PM
08/20/13 05:49 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
I did the same, except I put in my Doug's 2"ers in the spring of 2011. One tube bumped the passenger side shock tower and has by now self-clearanced, no other issues with the same setup as Mick. I used a fiber gasket, cranked it tight one time and have never had to re-tighten or have to try and seal them.
Are you hinting that you'll be driving the '71 soon?
dstryr, since 1986.
Re: Best 440 headers for 4spd clearance??? [Re: dstryr] #1487242
08/21/13 10:53 AM
08/21/13 10:53 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
2" TTI's on my 65 coronet w/440/4speed. no clearance issues.
Re: Best 440 headers for 4spd clearance??? [Re: 65rbdodge] #1487243
08/21/13 09:44 PM
08/21/13 09:44 PM
IN
ahy Offline
ahy  Offline
IN
I'm running 1 7/8" TTI's on an Ed head lowdeck with 5 speed. Clearance was fine with no clutch linkage (hydraulic which I like). I believe TTI provides Z bar modification instructions with a mechanical clutch linkage.
Re: Best 440 headers for 4spd clearance??? [Re: dstryr] #1487244
08/23/13 12:07 AM
08/23/13 12:07 AM
The Dark Side
Fasbird Offline OP
Fasbird  Offline OP
The Dark Side
Hey Frank!!! What's shakin'?
Yep, finally got the bug to get the 'ol horse back on the road. Putting it back together this fall/winter with the intentions of enjoying it in 2014. Heck!!! It's been apart since 2004!!!
