Page 1 of 3 1 2 3
possible state of emergency #1486442
08/18/13 08:49 PM
08/18/13 08:49 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
I broke a Manley 13093 valve lock. Summit and Jegs have ship dates of 8/26 on this item. I plan on calling Manley tomorrow but not sure if they will be much help
I found my lower ball joints (actually upper ball joints) moving up and down a half inch and replaced them with MOOG today. have yet to get the little grease fitting to screw in after a half hour of trying.
pulled the headers out to goop them up with red permatex in hopes they seal exhaust leaks.
didn't know I didn't need to pull the oil pump to change cams, which turned into dropping the pan for the 3rd time in 3 weeks. I'm stupid
I have showered and changed clothes 3 times, I'm a puddle of mud right now.
if anyone happens to have the valve locks I need, would you be willing to ship them to me and I'll buy you new ones(depending on what Manley tells me tomorrow)
the clock is ticking, and I'm getting nervous. Person I worked with for past 8 years quit and I'm trying to do the job of 2 people at work also.
Re: possible state of emergency [Re: sixpackgut] #1486443
08/18/13 09:15 PM
08/18/13 09:15 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: possible state of emergency [Re: pittsburghracer] #1486444
08/18/13 09:29 PM
08/18/13 09:29 PM
Charleston
Charleston
no, mine are a single bead at the very top of the lock. its a bit different than the norm
Re: possible state of emergency [Re: sixpackgut] #1486445
08/18/13 09:37 PM
08/18/13 09:37 PM
PA.
"Little"John
"Little"John
PA.
Picture may help so we can try to round you up some.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: possible state of emergency [Re: pittsburghracer] #1486446
08/18/13 10:03 PM
08/18/13 10:03 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Re: possible state of emergency [Re: ksj] #1486447
08/18/13 10:06 PM
08/18/13 10:06 PM
Charleston
Charleston
http://www.cnc-motorsports.com/manley-13...ysler-hemi.html
I saw that but they may not be in stock. Plan on calling them tomorrow also
Re: possible state of emergency [Re: sixpackgut] #1486448
08/18/13 10:11 PM
08/18/13 10:11 PM
Arizona
Chris'sBarracuda Offline
Arizona
Summit actually says 9/3 ship date..
Probably try Arrington?? http://www.shophemi.com/
Chris..
Re: possible state of emergency [Re: sixpackgut] #1486449
08/18/13 11:51 PM
08/18/13 11:51 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Here is clints Facebook page
https://www.facebook.com/clint.anderson.104?fref=ts
maybe you can get a quicker answer on it ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: possible state of emergency [Re: ksj] #1486450
08/19/13 10:31 AM
08/19/13 10:31 AM
Charleston
Charleston
CNC HAD THEM! THANK GOD
THANKS GUYS
Re: possible state of emergency [Re: sixpackgut] #1486451
08/19/13 10:39 AM
08/19/13 10:39 AM
Charleston SC
67383s Offline
67383s  Offline
Charleston SC
Glad you found them, Keep your head up, and call if you need an extra set of hands.
Steve Bright
Charleston SC
Re: possible state of emergency [Re: 67383s] #1486452
08/19/13 11:44 AM
08/19/13 11:44 AM
Charleston
Charleston
If you could just hose me down with cold water while I'm working that would be great, but there is no cold water in south Carolina in august
Re: possible state of emergency [Re: sixpackgut] #1486453
08/19/13 12:47 PM
08/19/13 12:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
don't you have a/c in the garage?
Re: possible state of emergency [Re: Quicktree] #1486454
08/19/13 01:09 PM
08/19/13 01:09 PM
Charleston
Charleston
I did, don't know if it still works because I swore I would never turn it on again. it ate money
Re: possible state of emergency [Re: sixpackgut] #1486455
08/19/13 01:15 PM
08/19/13 01:15 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
But that is the advantage living where you don't have to HEAT your house in the winter...We get to burn all of our $$$ in the winter here at 10°! Not to mention what snow removal equipment costs...
Good luck, and I am routing for you. Kicked A$$ last year, and really made a lot of us very happy to see you win..Wish they would have covered your car more in the vids...
Re: possible state of emergency [Re: Dragula] #1486456
08/19/13 01:57 PM
08/19/13 01:57 PM
Charleston
Charleston
thanks, I would run 3 times and leave before they even had their cameras setup most days.
and I'm from PA, I know all about paying for heat
Re: possible state of emergency [Re: sixpackgut] #1486457
08/19/13 02:45 PM
08/19/13 02:45 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Glad you found them Ray. I have about 175 miles on mine now and I hope to hit the track Friday night.
68 Barracuda Formula S 340
Re: possible state of emergency [Re: Bad340fish] #1486458
08/19/13 03:35 PM
08/19/13 03:35 PM
Dragula Offline
Dragula  Offline
Is that a little anemic Eddy carb on that engine? Most guys are running some pretty good size carb on them. How did you do the ignition set-up?
Re: possible state of emergency [Re: Dragula] #1486459
08/19/13 04:13 PM
08/19/13 04:13 PM
Charleston
Charleston
I just love when people hate on my carbs. for years everyone told me to take the six pack off, now its take the edelbrock off.
I have the MSD hemi 6 on it
Re: possible state of emergency [Re: sixpackgut] #1486460
08/19/13 04:52 PM
08/19/13 04:52 PM
Dragula Offline
Dragula  Offline
Not hating on it, but my understanding is the G3's prefer more carb than most conventional thinking would call for. What size is it? And I am pretty sure you ran a pair of them on your previous wedge combo...They take a little tinkering just like any carb. I am not famialiar with their Thunder series carbs either, just the old style ones.
On the ignition is it user programable? use setup the entire curve?
Re: possible state of emergency [Re: Dragula] #1486461
08/19/13 07:49 PM
08/19/13 07:49 PM
Charleston
Charleston
it has a timing curve that you can change. retard. rev limiter. map curve. works good
Page 1 of 3 1 2 3
