I have 0 vacuum on 69 Charger #1485748
08/17/13 03:05 PM
08/17/13 03:05 PM
St. Paul, MN
440 4 me Offline OP
440 4 me  Offline OP
St. Paul, MN
I have a 69 Charger 440. It is mostly stock. I rarely drive the car. Took it to the local cruise last night. The brake pedal was rock hard. The car falls on it's face if you punch it. This morning I put a vacuum gauge on it. It reads 0 at the inlet on the carb. Reads only 3 pounds at the brake booster. What are the common things I should check that would cause low vacuum?
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485749
08/17/13 04:13 PM
08/17/13 04:13 PM
which port on which carb are you getting a zero reading? Is that at idle? Low vac from a massive vacuum leak but more info as something is missing
Re: I have 0 vacuum on 69 Charger [Re: RapidRobert] #1485750
08/17/13 04:24 PM
08/17/13 04:24 PM
St. Paul, MN
440 4 me Offline OP
440 4 me  Offline OP
St. Paul, MN
Getting 0 vacuum at the port at the front/base of the carb. Carb is stock is most everything else on engine.
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485751
08/17/13 04:27 PM
08/17/13 04:27 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Take your reading at the vacuum port, on the back of the intake manifold.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485752
08/17/13 04:32 PM
08/17/13 04:32 PM
I just took my AVS out to the garage so I dont have it in front of me on the kitchen table to check it but I would assume that that front mini port nipple is "ported" & would (& should) have zero vac at idle. 3 in hg at the booster ain't right tho & definitely will not activate the booster but I'm not seeing (yet) how it could be that low. Where are you mounting the gauge?
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485753
08/17/13 04:33 PM
08/17/13 04:33 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
timing chain jumped???
Re: I have 0 vacuum on 69 Charger [Re: Dodgem] #1485754
08/17/13 04:37 PM
08/17/13 04:37 PM
hemi71x Offline
hemi71x  Offline
X2
Severely retarded timing.
Re: I have 0 vacuum on 69 Charger [Re: hemi71x] #1485755
08/17/13 04:42 PM
08/17/13 04:42 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yup when they jump back a tooth they sure loose power and vacuum + the timing moves the same number of degrees back!
Re: I have 0 vacuum on 69 Charger [Re: hemi71x] #1485756
08/17/13 08:29 PM
08/17/13 08:29 PM
St. Paul, MN
440 4 me Offline OP
440 4 me  Offline OP
St. Paul, MN
Found a hose that had a crack in the center... I get about 13 pounds of vacuum. Still not enough to make the brake booster work properly...
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485757
08/17/13 08:42 PM
08/17/13 08:42 PM
You might bump the initial up a bit to up the vacuum keeping in mind that that may require dist mods (springs, slots) to compensate.
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485758
08/17/13 11:35 PM
08/17/13 11:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
13 inches of vacuum is more than enough something else must be wrong.
Re: I have 0 vacuum on 69 Charger [Re: Dodgem] #1485759
08/17/13 11:50 PM
08/17/13 11:50 PM
Good point
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485760
08/18/13 10:21 AM
08/18/13 10:21 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Perhaps your brake booster needs a rebuild. I have 10" vacuum and I have plenty of brake power. Do you have a vacuum canister hooked up to the manifold? My 69 needs to have a vacuum pump because of the cam, the power brakes, and the headlight system..
One thing at a time though
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: I have 0 vacuum on 69 Charger [Re: RapidRobert] #1485761
08/19/13 12:39 AM
08/19/13 12:39 AM
St. Paul, MN
440 4 me Offline OP
440 4 me  Offline OP
St. Paul, MN
My guess is the brake booster is just shot. Any suggestions on how to test it? I was trying to think of what I could use to run vacuum directly to the booster. My hand held "Mityvac" has enough pressure, but does not draw enough volume.
Assuming I do need a new brake booster, does anyone have suggestions as to where to get a correct one? The car is fairly correct so I would want to get to get a booster that has the correct yellow zinc (if that is what the coating is).
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485762
08/19/13 12:50 AM
08/19/13 12:50 AM
IN
ahy Offline
ahy  Offline
IN
To test the brake booster for leaks, securely plug the vacuum line feeding it and see if the problem persists. For the booster, I'm running a Cardone reman. It is (or was) available at an AP store. It is the correct type and cost effective but has black anti-rust coating and no new plating.
Re: I have 0 vacuum on 69 Charger [Re: ahy] #1485763
08/19/13 10:46 AM
08/19/13 10:46 AM
St. Paul, MN
440 4 me Offline OP
440 4 me  Offline OP
St. Paul, MN
When I disconnect the booster and block it's line the vacuum gauge does not change. So it does not seem like the booster is leaking. However, the brakes are really hard to push with the vacuum line connected. I get about 10 - 13 pounds vacuum so I would think that would be enough to make it work.
Can anyone recommend where I can buy a booster that is original appearing and is not crazy expensive (aka YearOne - they want $499 for theirs).
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485764
08/19/13 10:50 AM
08/19/13 10:50 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Rock Auto and Napa sells them reman for a lot less.
Don't be the exception.
Re: I have 0 vacuum on 69 Charger [Re: 440 4 me] #1485765
08/19/13 09:18 PM
08/19/13 09:18 PM
IN
ahy Offline
ahy  Offline
IN
Vacuum is commonly measured in inches of mercury. In round numbers, 30 in mercury = 15 psi. 10 psi vacuum would be 20 inches mercury which is very good for a healthy engine and stock cam. Agree more than enough for power brakes.
Re: I have 0 vacuum on 69 Charger [Re: ahy] #1485766
08/19/13 10:23 PM
08/19/13 10:23 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I suspect that he is mis-speaking and means 10-13 inches Hg.
