I went out a few weeks ago and the car ran fine the first pass, but the next pass the car bogged bad off the line. I pulled the carb apart and used carb cleaner to run through the air bleeds, metering block and squirters. It ran good the next pass and then bogged the following, so I loaded the car up and left. The next day I checked the fuel filter and there was a little trash in it. I flushed all of the fuel out of the tank, changed the filter, soaked the carb overnight in carb cleaner, installed a rebuild kit and installed a new fuel filter. I went back out to the track the following week and still had a bog. I have also changed the distributor cap and rotor and installed new spark plugs. I pulled the sending unit and pick up from the tank and everything looks good. I still have a bog.
The set up is as followed-
E85 950 HP
BG220 Pump, Regulator and filter
10 an feed to an 8 an on the supply side
10 an return
FYI the car does not sit for any extended times, it is driven daily. Any ideas were to look next?
