A Body Manual Steering Questions #1485186
08/16/13 12:03 AM
08/16/13 12:03 AM
McHenry, Illinois
RAUPLEMINZE454 Offline OP
McHenry, Illinois
Hey guys,
I have a manual steering box out of either a 70 duster or 71 demon that will be installed in a current project.  Is there any rebuild kits offered for these?  Is it a simple process?  If not are there any places to send it to be rebuilt?
Thanks in advance,
Brian
Re: A Body Manual Steering Questions [Re: RAUPLEMINZE454] #1485187
08/16/13 12:30 AM
08/16/13 12:30 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Firm Feel used to offer a rebuild kit for them, don't know if it's still available. It's a messy job, but not all that complicated. I advise doing it in a tray so that you don't lose any of the sector shaft needle bearings as they are NOT part of the rebuild kit. Set worm gear preload first then the sector shaft. Sector shaft must be on the high spot [ middle of travel ] when setting preload.
Re: A Body Manual Steering Questions [Re: RAUPLEMINZE454] #1485188
08/16/13 09:17 AM
08/16/13 09:17 AM
Penna
70satelliteguy Offline
Penna
http://www.carsteering.com
I got one last winter and it works great!!!!!!!!
Mike
Re: A Body Manual Steering Questions [Re: 70satelliteguy] #1485189
08/16/13 09:27 AM
08/16/13 09:27 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Mike
You got a rebuild kit from them?
Don't be the exception.
Re: A Body Manual Steering Questions [Re: 5spdcuda] #1485190
08/16/13 09:36 AM
08/16/13 09:36 AM
No Mas
Re: A Body Manual Steering Questions [Re: 5spdcuda] #1485191
08/24/13 02:48 PM
08/24/13 02:48 PM
McHenry, Illinois
McHenry, Illinois
Thanks for the advice, I looked on their site and saw pricfes for rebuild kits but have yet to try and contact them.
"FFI Rebuild
MSB1.......$329
Steering Core Charge
MSC........$200
Rebuild Kits
MSBK1.......$50
MSBK2......$100
*MSBK3.....$200*
(*Plus $50 Worm Gear Core)
MSBKC.......$50
Pot Connector Kit
PK0.........$25"
I inspected the box the other day and when simulating a turn and spinning the gears there is a definite rough spot. I still have yet to open it up because I am trying to figure out my options.
Thanks,
Brian
