72 Duster disc brakes #1485012
08/15/13 01:24 PM
08/15/13 01:24 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
These would be small bolt pattern correct?
I just bought a 68 Dart with front drums. Will the entire 72 k-member setup bolt into the 68? Is there a replacement rotor available that has the 4.5" bolt pattern?
Re: 72 Duster disc brakes [Re: burdar] #1485013
08/15/13 02:35 PM
08/15/13 02:35 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Pretty sure, 74 and up (A body) were all the big bolt pattern . . . that is what I have on my 74 Duster360.
Cheers
Mark
Re: 72 Duster disc brakes [Re: a12rag] #1485014
08/15/13 02:40 PM
08/15/13 02:40 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
All A bodies built before 1973 used the small bolt pattern whether drum or disc EXCEPT the 68 SS Dart and Barracuda HEMI cars.
In 1973, the drum brake cars still used the small bolt pattern while the disc cars had the larger bolt pattern. The A body cars actually could have still had drum brakes into the early built 1976 models! I owned a 76 Dart with a 225, a 904 and 4 wheel 9 inch drum brakes.
Re: 72 Duster disc brakes [Re: a12rag] #1485015
08/15/13 05:17 PM
08/15/13 05:17 PM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
I believe that's where my front disc brake upgrade parts came from.
Re: 72 Duster disc brakes [Re: burdar] #1485016
08/15/13 05:37 PM
08/15/13 05:37 PM
These would be small bolt pattern correct? Will the entire 72 k-member setup bolt into the 68? Is there a replacement rotor available that has the 4.5" bolt pattern?
Yes you could bolt in the whole 72 k member setup with discs which'd have SBP. If the rear axle is BBP & that's what you're after all the way around you MAY be able to get an adapter to run a BBP rotor on the SBP disc spindle or if not I know there's an adapter to use the 73-76 A body disc spindles/BBP rotors on the small upper ball joint (early) upper control arms which you have now so you could get BBP up front if that's the goal
Re: 72 Duster disc brakes [Re: burdar] #1485017
08/15/13 05:45 PM
08/15/13 05:45 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
There is now a rotor available with the 4 1/2 inch bolt pattern, for the Kelsey Hayes, 4 piston caliper, disc brake system.
It's nothing more than a Mustang rotor, re machined internally, for the bearing and race used on a Mopar spindle.
The aftermarket vendor that does that work, and sells them, is The Ram Man.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 72 Duster disc brakes [Re: hemi71x] #1485018
08/15/13 06:29 PM
08/15/13 06:29 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
Or just find a good machinist and do it yourself:
http://www.forabodiesonly.com/mopar/showthread.php?t=20544&highlight=mustang+rotors
vm
Re: 72 Duster disc brakes [Re: vynn3] #1485019
08/15/13 10:42 PM
08/15/13 10:42 PM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Thanks everyone. Exactly what I needed to know.
