Re: 69 1/2 rr 'sloppy' steering
[Re: paris401]
#1484963
08/15/13 10:10 PM
08/15/13 10:10 PM
Posts: 654 MN
astrobuf
MN
I had this problem. My front end components were tight, but one of my LCA shaft's was plugged into its K-Frame sleeve and the sleeve weld was broken. Have you actually used a pry bar with the car up on a lift to see just how rigid the suspension is?
Astrobuf
So, are you really a Rocket Scientist?
[Re: JohnRR]
#1484970
08/16/13 10:43 PM
08/16/13 10:43 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
I think only the A body /6 cars had a bushing , everything else has a bearing , but good thing to check.
Box on my car was from a slant 6 car, I installed it to save the pounds and HP.
Now I'm getting old and putting the PS back in.
[Re: gdonovan]
#1484971
08/17/13 12:26 AM
08/17/13 12:26 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
his box would not have a bushing then.
Ron also look at the coupler to column shaft connection.
[Re: JohnRR]
#1484972
08/17/13 05:22 AM
08/17/13 05:22 AM
gdonovan
Oakdale CT
A lot happens in 40+ years, who is to say it has the original correct box in it?
I worked in a yard doing inventory for a friend, it was scary what the Hollander book said would "interchange"
