Page 2 of 3 1 2 3
Re: Aftermarket RB blocks? [Re: Thumperdart] #1483237
08/13/13 03:04 PM
08/13/13 03:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Gee I wonder what my KB low deck B1 would make with an iron block under it...What a turd it is
FWIW aluminum is the way to go. EVEN IF there were a HP difference the weight avings will FAR overcome any perceived loss in HP It I a 100+ pound savings.
Re: Aftermarket RB blocks? [Re: Thumperdart] #1483238
08/13/13 03:10 PM
08/13/13 03:10 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
My aluminum blocks, I've used World, KB, and Indy, all made very close to the same power (within 10HP) that my steel blocks did. My world and KB engines had zero leak down when fresh, warm, and 2% when tired. Steel, is not worth the extra weight IMO.
Re: Aftermarket RB blocks? [Re: Al_Alguire] #1483239
08/13/13 03:12 PM
08/13/13 03:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It was just a point Al........... No one said an alum. block didn`t make power........... WAY too many egos.........
Re: Aftermarket RB blocks? [Re: camastomcat] #1483240
08/13/13 03:45 PM
08/13/13 03:45 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Oh...and I would never buy another World aluminum block......ever!
Re: Aftermarket RB blocks? [Re: camastomcat] #1483241
08/13/13 04:06 PM
08/13/13 04:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Dom no ego at all. Just saying I think the amount is negligible. I to have had this very discussion with Jason myself. Kinda falls in the same realm as aluminum rods are only good for a hundred passes or so. Was true a few years ago but I think with the advances in technology and metallurgy that many things are not as they were "back in the day" so to speak. You know where my junk came from. I just don't think many of thee old "wives tales" still hold true these days.
How much more power is the iron block going to make over an aluminum one? Possibly in a very high RPM, very high HP per cube deal there is more power to be had with iron, or better yet compacted graphite but for 99.9% of users I just don't think it is a concern. Now if you are a Comp or Pro Stock racer then maybe it is worth the added cost to use a CG block.
Re: Aftermarket RB blocks? [Re: Al_Alguire] #1483242
08/13/13 04:18 PM
08/13/13 04:18 PM
Cab_Burge Online work
Cab_Burge  Online Work
Being a old class racer where every HP and every .0001 counts I want to make sure everyone on here is aware of what I'm aware of Al, as far as high RPM you know who I'm using as a reference BTW, isn't your 99 hemi block iron Lots of options out there
Re: Aftermarket RB blocks? [Re: Al_Alguire] #1483243
08/13/13 04:23 PM
08/13/13 04:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It`s all good man................I`m just repeating what I heard and when/if I can afford one, I`ll go alum. for the weight savings alone.
Re: Aftermarket RB blocks? [Re: Cab_Burge] #1483244
08/13/13 04:26 PM
08/13/13 04:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Seriously Cab how many people on here care enough to find every last .0001 in their combinations. Heck the average guy cries about changing converters or buying good shocks. You think they really want, care or need that last 15 hp??
Yep compacted graphite actually. Nothing else under $10K available. Also not your average bracket deal, 10,200 RPM scares most folks away for sure. HOWEVER trust me when I win the lottery those heads will have a CN block underneath them for sure. Oh yeah that motor weighs in at 884lbs as well
I stand by what I said. 99.9% of the racers out there will not see enough HP from an iron block to overcome the additional weight they carry.
Re: Aftermarket RB blocks? [Re: AndyF] #1483245
08/13/13 04:48 PM
08/13/13 04:48 PM
New Jersey
Randy514 Offline OP
Randy514  Offline OP
New Jersey
Randy,
Read my "514 on the dyno" thread when you get a chance. I've already been down the road that you're taking. I used a World iron block but the rest if fairly similiar. If you read that thread carefully and look at the pictures you'll get some ideas.
Andy where would one find this 514 on the dyno thread I tried doing a search :-(
Re: Aftermarket RB blocks? [Re: Al_Alguire] #1483246
08/13/13 04:48 PM
08/13/13 04:48 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
100%. Way to many guys sitting at home polishing their dynos instead of hitting the track for some real life numbers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Aftermarket RB blocks? [Re: Al_Alguire] #1483247
08/13/13 05:02 PM
08/13/13 05:02 PM
What a contradictory statement....The Aluminum Block is $2k+ more than the iron....so the ¨average guy that cries about changing converters or buying good shocks¨ will of course opt for the 2k cheaper iron block and the extra 15hp that weighs 100 lbs. more.....
Re: Aftermarket RB blocks? [Re: ] #1483248
08/13/13 05:46 PM
08/13/13 05:46 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
In the deep skirt "Y" block MOPAR world, a good iron block is 300++, while it's aluminium counterpart is half that, or less.
How much horsepower increase does it take to make up a 150+ pound difference in weight to run identical ETs???
Try to repair an iron block, or bore it numerous times. Short of an epic explosion, the aluminum block can be repaired and re-sleeved.
There are numerous modern day "fixes" to get the power difference very negligible as well.
To me, it's a no brainer and if money isn't tight a billet block kills.
Re: Aftermarket RB blocks? [Re: Cab_Burge] #1483249
08/13/13 06:25 PM
08/13/13 06:25 PM
Delray beach, Florida
P
Performance Only Offline
P
I'm a naysayer when it comes to N/A motors and aluminum blocks do to the inherit problems on ring seal They won't hold as good as ring seal as the cast grey iron, high nickel and compact graphite iron will The iron blocks are heavier, 325 lbs.+
Cab, One of the things I see quite often is aluminum blocks that were improperly honed, causing all sorts of ring seal issues. Depending on several factors, that alone can cause a major loss of power. I would tell anyone that's going to use an aluminum block to make sure their choice of shop knows the difference between the material the liners are made of and a grey cast iron cylinder, or at the very least, contact the manufacturer for honing instructions.
machine shop owner and engine builder
Re: Aftermarket RB blocks? [Re: ] #1483250
08/13/13 07:37 PM
08/13/13 07:37 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I don't know if you have been watching prices lately, but e NEW cast iron block can run you $2900-$3500 and an Indy Maxx aluminum block is $4300...Not so much of a stretch really. I lucked out and got a new block for $2700 delivered and no taxes.
Re: Aftermarket RB blocks? [Re: Randy514] #1483251
08/13/13 08:02 PM
08/13/13 08:02 PM
AndyF Online content
AndyF  Online Content
Randy,
https://board.moparts.org/ubbthreads/show...rue#Post7789182
Re: Aftermarket RB blocks? [Re: Dragula] #1483252
08/13/13 10:36 PM
08/13/13 10:36 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
That's a pretty raw aluminum block that still needs some machine work......really, the KB and Indy Maxx are the same price when they are ready to run. KB just considers a block to be assembly ready.
Re: Aftermarket RB blocks? [Re: camastomcat] #1483253
08/14/13 12:54 AM
08/14/13 12:54 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I'm planning on going aluminum 540 in november. I made a post on another site about an Indy Maxx block and got whipped up on, so to speak. I was going to let Josh Handle it. But thought about it today until I decided I may just order the block and rotating assembly and do it myself. Then after this post, I was thinking of maybe contacting performance only and seeing if he could do my B1 short block and maybe even the full assembly. I have been quite busy all over the Northern continent and hadn't had much time. I plan on a 4.5 bore 4.25 stroke in an r block with rb mains so far.And use one of the sets of my B1 originals I have. I had even considered a KB block. If I can get my dart down to 2350 lbs and around 950 hp, I feel I would have a strong solid combo. I may keep my 511 B1 steel block engine as a spare, or put it in something else.
Re: Aftermarket RB blocks? [Re: Dragula] #1483254
08/14/13 01:59 AM
08/14/13 01:59 AM
NASHVILLE
MAVERICKSHEMI Offline
NASHVILLE
KB if you have the time to spare & $$
Indy Max would be my second choice, just purchase it thru one of their dealers.
In my dealings with World Products, I will effectively say, they match Indy for horrible customer service and $hitty attitude...And I will NEVER buy anything again with their logo on it, keep it I don't need the issues or the attitude that comes with it!
Re: Aftermarket RB blocks? [Re: Al_Alguire] #1483255
08/14/13 02:11 PM
08/14/13 02:11 PM
Let me qualify my reasonings on block choices, for all out power on a N/A motor would be compact graphite iron first, cast grey iron second and billet aluminum block third with cast aluminum last. For a street or bracket motor it would be a stock cast grey iron unless soemone gave me a aluminum block for free or testing, any offers All kidding aside as Al pointed out, when your not going for all out results, high HP and high RPM, above 7000 RPM then aluminum will seal fine for most appliction, above 7000 RPM you want the best ring seal you can get(vacume pump grounds) and most aluminum blocks will not seal as good as most good cast iron blocks will One of the things that is taught in comercial flying is the expansion differences between aluminum, iron and steel, especially in motors. Aluminum expands 8 times more than steel and iron Hence the need to set the valve lash tighter when cold on a motor with aluminum heads, even more on a all aluminum motor. So if you want 15.0 to 1 compression you better allow for the block and head growth when machining that kind of motor so you get what you want, allow for block growth up and out as well as the combustion chamber growth Enough pot stirring stimulation from me today
Re: Aftermarket RB blocks? [Re: Mopar-Al] #1483256
08/14/13 02:11 PM
08/14/13 02:11 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I had that exact combo in my dragster. It was a KB water low deck block, Callies 4.25 stroke, 4.505 bore, M/C heads, 16-1 compression, MGP rods, Jessel belt drive. I needed a lot looser converter, it only stalled at 5200 RPM, than I had but it went 7.65@174 in Utah at 8000ft. corrected. I needed more torque so I went back to a 572. I have a lot of the stuff for sale. I sent you a PM.
Page 2 of 3 1 2 3
