400 vs 440 stroker. #1482570
08/10/13 09:47 PM
08/10/13 09:47 PM
jersey
Spaceman Spiff Offline OP
jersey
If you wanted to build a 500ish in stroker to make 600hp, and you had 84cc edelbrock heads, would you do a 400 or 440 based build, and why?
Going into a '58 Plymouth with a/c and a 3.73 geared rear.
Hydraulic flat tappet, or hydraulic roller and why?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 400 vs 440 stroker. [Re: Spaceman Spiff] #1482571
08/10/13 10:07 PM
08/10/13 10:07 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
600hp on a 500 inch stroker is like detuning it...
We currently run a 512 RB with out of the box EZ heads, and is making 700hp on pump gas. We run a solid mechanical cam, 10.7:1 pistons, and a 950 Proform carb jetted up at least 2 all the way around. The block was treated to a girdle and a big oil pan, but not much else...Our cam is about .670" but you can detune it with a mild street cam. I normally don't care for Eddy heads, and about where they flow fully ported are about where these start out of the box.
Watch piston choice with the bigger 84cc heads.
Our next build is going to basically a copy of this engine with a 400 block and the same heads with a mild port job...Why, because the 400 will fit in the Duster better, has smaller main journels, and should be slightly lighter. We are going to put a Dominator on the next one as well.
Re: 400 vs 440 stroker. [Re: Dragula] #1482572
08/10/13 10:46 PM
08/10/13 10:46 PM
IN
ahy Offline
ahy  Offline
IN
It sounds like a fast street car/cruiser. The low deck 512 with ~6.535 rods works great as a drag engine but probably wants bigger heads. The low deck 496 with 6.76" rods uses a short piston... light, fast revving but maybe not the best durability. That's what I'm running with Ed heads.
Either could be good but I'd suggest the RB with 4.125" stroke for your setup. It uses a slightly taller piston and should work well with the Ed heads. With block machining and piston selection it is pretty easy to build a zero deck engine. Matched up with a common gasket in the .038-.040 range you get perfect quench. You will need a dish piston to get CR in the pump gas range (low 10's to 11 depending on cam).
I would and did go flat tappet. Adapting the RB for roller is expensive and a bit tricky I think. A solid flat tappet will give great performance. Break in, high zinc oil and maybe EDM drilled lifters make it reliable. Your stroker won't need to spin much past 6000 so springs don't need to be crazy stiff.
I worked with Mike at Muscle Motors to get my rotating assembly, cam and heads speced out and matched up.
Re: 400 vs 440 stroker. [Re: Dragula] #1482573
08/10/13 10:48 PM
08/10/13 10:48 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
wanting to do the same for my next build looking at the weight saving in a a-body
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 400 vs 440 stroker. [Re: Spaceman Spiff] #1482574
08/10/13 10:51 PM
08/10/13 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A 400 block is much stronger... that would be the only
way I'd go unless you wanted way more CI
Re: 400 vs 440 stroker. [Re: ahy] #1482575
08/10/13 10:51 PM
08/10/13 10:51 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
Why?
Re: 400 vs 440 stroker. [Re: Nitrojunkee] #1482576
08/10/13 11:18 PM
08/10/13 11:18 PM
Dragula Offline
Dragula  Offline
Myy engine builder keeps mentioning the piston speed and rod ratio are much better with the 400 based engine as well. Generally when they mention that, they are concerned with the strain the piston puts on the cylinder wall..
Re: 400 vs 440 stroker. [Re: Spaceman Spiff] #1482577
08/10/13 11:30 PM
08/10/13 11:30 PM
AndyF Offline
AndyF  Offline
I did that engine a few years ago. From the tech archives: http://www.popularhotrodding.com/tech/1007phr_big_block_mopar_engines/
Re: 400 vs 440 stroker. [Re: Dragula] #1482578
08/10/13 11:32 PM
08/10/13 11:32 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Dragula, what car is this motor in? What ET is it running and at what weight?
Re: 400 vs 440 stroker. [Re: ProSport] #1482579
08/10/13 11:42 PM
08/10/13 11:42 PM
Dragula Offline
Dragula  Offline
We run that in the Duster...3150lbs with me in it ran 10.07 leaving at only 2100rpm shifting at only 6400...We are not running it as hard as we could.
Re: 400 vs 440 stroker. [Re: Dragula] #1482580
08/10/13 11:55 PM
08/10/13 11:55 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Ok, I am just wondering why you don't care for Edelbrocks, I used ported Eddy's on my pump gas 451 with the 590 cam and went 9.80's at 3050#'s. I love these heads and I'm dropping my 500" low deck into my Duster tomorrow with MW cnc ported Eddy's.
Re: 400 vs 440 stroker. [Re: ProSport] #1482581
08/11/13 12:07 AM
08/11/13 12:07 AM
Dragula Offline
Dragula  Offline
I just think that where the E-heads finish up is where the Indy heads tend to start...Ours are out of the box literally. Last time we tried a 3k launch, it killed all the tabs on the rear suspension. Bent everything. We have a much better rear set-up now, and might wick it up a bit this weekend we will see.
Re: 400 vs 440 stroker. [Re: Nitrojunkee] #1482582
08/11/13 03:01 PM
08/11/13 03:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why?
That`s what I was thinking..........my Isky solid roller has been flawless for around 8 years and the lifters just drop in..........no bushed bores OR lightning/oil bands(solid body).
Re: 400 vs 440 stroker. [Re: Thumperdart] #1482583
08/11/13 04:08 PM
08/11/13 04:08 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You haven't stated purpose but if A/C is involved I'm assuming station wagon street stealth bomber .
My 440 based if for no other reason than I buy into the long rod theory as far as longevity is concerned ie for me a build like this is a failure if it won't go 200,000 miles minimum without pulling the heads.
My 440 based 493 is 0 deck 8.97:1 and did 500hp 600ft/lbs on 87 regular with OOTB RPM's and a MP509. Depending on what you are willing to live with as far as street manners are concerned, more cam and compression would get mine pretty close I think and a trip to the head porter would put it over the top but at the expense of longevity IMHO.
I'd buy enough cylinder head to hit your number with and build as big a short block as I needed to make it happen by 5500 and it should run strong forever.
Kevin
Re: 400 vs 440 stroker. [Re: Thumperdart] #1482584
08/11/13 08:05 PM
08/11/13 08:05 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
Why?
Yep. I'm going with a solid roller custom blower grind from Bullet, and a set of Morel lifters. Not bushing the lifter bores, and I'm not worried about it. Of course, I won't be spinning this motor past 6300-6500 either... If that. I'm also going to spend a little coin on rockers, and lighter valve train parts.
Re: 400 vs 440 stroker. [Re: Twostick] #1482585
08/11/13 08:13 PM
08/11/13 08:13 PM
CO
N
Nitrojunkee Offline
Nitrojunkee  Offline
N
CO
Kevin
Couldn't agree more with this! More cubic inch with some good flowing heads, won't have to work as hard. Not that there is anything wrong with the low deck big inch builds, I've seen some killer ones! My 496" is a 440 base, 4.150" stroke, 2.200" journal, with 6.800" rod length. Still plenty of compression height on Diamond 8.98:1 dish blower pistons at zero deck. Didn't skimp on machine work either. I'm banking on it lasting me 8-10 years before it needs freshening up... We shall see.
I'd go 440, but I could be biased
Re: 400 vs 440 stroker. [Re: Nitrojunkee] #1482586
08/11/13 10:03 PM
08/11/13 10:03 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I would go with a 400 block.....Did you see the bob weight on these combo ?
Re: 400 vs 440 stroker. [Re: Spaceman Spiff] #1482587
08/12/13 01:29 AM
08/12/13 01:29 AM
400 block with a 4.300 sroker crank with either 6.700 or 6.600 long BB Chevy h beam rods, pistons made to match the compression ratio you want. Hydraulic roller for the longivity Shift that rascal around 6000 RPM and hope you can hook it
Re: 400 vs 440 stroker. [Re: Cab_Burge] #1482588
08/12/13 09:03 AM
08/12/13 09:03 AM
gregsdart Offline
gregsdart  Offline
I am in favor of a low deck for high rpm big head horsepower. But your deal is different, so either will work well. The RB block will allow you to go to 570 cubes if you can find a 4.75 stroke crank and 4.375 bore, or you can go 540 with a 4.5 stroke. You just can't beat big cubes when you are going to put a road gear in the car and it is HEAVY. The BIG motor will allow you to go with a 3.23 gear and have the same torque as a 500 with the 3.73 at the rear axles, and you can then tighten the converter some to make it lock up better, reducing the rpm even more. I built a 535 with 906 heads many years ago, and all I had was a stock high stall 340/Hemi 10 3/4 factory converter. It would stall 3700 rpm with a 590 cam in it! Too bad it only lasted six passes. So in your case, given you find blocks in either size that are in good shape, go big. If the best block you find (sonic check) is a low deck, then I would go with it. Ring seal is also important, and you don't want to split a cylinder by using a marginal block.
Re: 400 vs 440 stroker. [Re: gregsdart] #1482589
08/16/13 11:26 AM
08/16/13 11:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
A question is how big is the engine compartment in the car this is going in ? If it's tight then use the 400 block , if not then I would use the RB , better intake choices and a taller piston which will be more stable in a street engine .
I'd also look at a stepping up to a roller cam if you are planning on going to a roller tip rocker setup for longevity and less with the oil and flat tappet issues ... assuming the budget allows.
