400 vs 440 stroker.
#1482570
08/10/13 09:47 PM
08/10/13 09:47 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
If you wanted to build a 500ish in stroker to make 600hp, and you had 84cc edelbrock heads, would you do a 400 or 440 based build, and why? Going into a '58 Plymouth with a/c and a 3.73 geared rear.
Hydraulic flat tappet, or hydraulic roller and why?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 400 vs 440 stroker.
[Re: Spaceman Spiff]
#1482571
08/10/13 10:07 PM
08/10/13 10:07 PM
Posts: 12,386 Taxes & Virus's R-US, NY
Dragula
600hp on a 500 inch stroker is like detuning it...
We currently run a 512 RB with out of the box EZ heads, and is making 700hp on pump gas. We run a solid mechanical cam, 10.7:1 pistons, and a 950 Proform carb jetted up at least 2 all the way around. The block was treated to a girdle and a big oil pan, but not much else...Our cam is about .670" but you can detune it with a mild street cam. I normally don't care for Eddy heads, and about where they flow fully ported are about where these start out of the box.
Watch piston choice with the bigger 84cc heads.
Our next build is going to basically a copy of this engine with a 400 block and the same heads with a mild port job...Why, because the 400 will fit in the Duster better, has smaller main journels, and should be slightly lighter. We are going to put a Dominator on the next one as well.
#1482574
08/10/13 10:51 PM
08/10/13 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
A 400 block is much stronger... that would be the only way I'd go unless you wanted way more CI
[Re: ahy]
#1482575
08/10/13 10:51 PM
08/10/13 10:51 PM
Posts: 47 CO
Nitrojunkee
CO
Adapting the RB for roller is expensive and a bit tricky I think.
Why?
[Re: Dragula]
#1482578
08/10/13 11:32 PM
08/10/13 11:32 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Dragula, what car is this motor in? What ET is it running and at what weight?
[Re: ProSport]
#1482579
08/10/13 11:42 PM
08/10/13 11:42 PM
Dragula
We run that in the Duster...3150lbs with me in it ran 10.07 leaving at only 2100rpm shifting at only 6400...We are not running it as hard as we could.
[Re: ProSport]
#1482581
08/11/13 12:07 AM
08/11/13 12:07 AM
Dragula
Ok, I am just wondering why you don't care for Edelbrocks, I used ported Eddy's on my pump gas 451 with the 590 cam and went 9.80's at 3050#'s. I love these heads and I'm dropping my 500" low deck into my Duster tomorrow with MW cnc ported Eddy's.
I just think that where the E-heads finish up is where the Indy heads tend to start...Ours are out of the box literally. Last time we tried a 3k launch, it killed all the tabs on the rear suspension. Bent everything. We have a much better rear set-up now, and might wick it up a bit this weekend we will see.
[Re: Thumperdart]
#1482583
08/11/13 04:08 PM
08/11/13 04:08 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You haven't stated purpose but if A/C is involved I'm assuming station wagon street stealth bomber . My 440 based if for no other reason than I buy into the long rod theory as far as longevity is concerned ie for me a build like this is a failure if it won't go 200,000 miles minimum without pulling the heads. My 440 based 493 is 0 deck 8.97:1 and did 500hp 600ft/lbs on 87 regular with OOTB RPM's and a MP509. Depending on what you are willing to live with as far as street manners are concerned, more cam and compression would get mine pretty close I think and a trip to the head porter would put it over the top but at the expense of longevity IMHO. I'd buy enough cylinder head to hit your number with and build as big a short block as I needed to make it happen by 5500 and it should run strong forever. Kevin
[Re: Thumperdart]
#1482584
08/11/13 08:05 PM
08/11/13 08:05 PM
Posts: 47 CO
Nitrojunkee
CO
Why?
That`s what I was thinking..........my Isky solid roller has been flawless for around 8 years and the lifters just drop in..........no bushed bores OR lightning/oil bands(solid body).
Yep. I'm going with a solid roller custom blower grind from Bullet, and a set of Morel lifters. Not bushing the lifter bores, and I'm not worried about it. Of course, I won't be spinning this motor past 6300-6500 either... If that. I'm also going to spend a little coin on rockers, and lighter valve train parts.
[Re: Twostick]
#1482585
08/11/13 08:13 PM
08/11/13 08:13 PM
Posts: 47 CO
Nitrojunkee
CO
Kevin
Couldn't agree more with this! More cubic inch with some good flowing heads, won't have to work as hard. Not that there is anything wrong with the low deck big inch builds, I've seen some killer ones! My 496" is a 440 base, 4.150" stroke, 2.200" journal, with 6.800" rod length. Still plenty of compression height on Diamond 8.98:1 dish blower pistons at zero deck. Didn't skimp on machine work either. I'm banking on it lasting me 8-10 years before it needs freshening up... We shall see.
I'd go 440, but I could be biased
#1482587
08/12/13 01:29 AM
08/12/13 01:29 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
400 block with a 4.300 sroker crank with either 6.700 or 6.600 long BB Chevy h beam rods, pistons made to match the compression ratio you want. Hydraulic roller for the longivity Shift that rascal around 6000 RPM and hope you can hook it
[Re: Cab_Burge]
#1482588
08/12/13 09:03 AM
08/12/13 09:03 AM
Posts: 9,996 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am in favor of a low deck for high rpm big head horsepower. But your deal is different, so either will work well. The RB block will allow you to go to 570 cubes if you can find a 4.75 stroke crank and 4.375 bore, or you can go 540 with a 4.5 stroke. You just can't beat big cubes when you are going to put a road gear in the car and it is HEAVY. The BIG motor will allow you to go with a 3.23 gear and have the same torque as a 500 with the 3.73 at the rear axles, and you can then tighten the converter some to make it lock up better, reducing the rpm even more. I built a 535 with 906 heads many years ago, and all I had was a stock high stall 340/Hemi 10 3/4 factory converter. It would stall 3700 rpm with a 590 cam in it! Too bad it only lasted six passes. So in your case, given you find blocks in either size that are in good shape, go big. If the best block you find (sonic check) is a low deck, then I would go with it. Ring seal is also important, and you don't want to split a cylinder by using a marginal block.
[Re: gregsdart]
#1482589
08/16/13 11:26 AM
08/16/13 11:26 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
A question is how big is the engine compartment in the car this is going in ? If it's tight then use the 400 block , if not then I would use the RB , better intake choices and a taller piston which will be more stable in a street engine . I'd also look at a stepping up to a roller cam if you are planning on going to a roller tip rocker setup for longevity and less with the oil and flat tappet issues ... assuming the budget allows.
[Re: Cab_Burge]
#1482591
08/16/13 07:57 PM
08/16/13 07:57 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
I have had 4 stroked 400 combos so you know what my answer is. The 451 in my 3100lb Demon went 10.07 with max wedge ported Indy SR's. My 69 Charger went 12.07 with a Eddy Rpm Headed 451. Demon went 9.56 with a 400 based 512 with the same Indy heads and same cam. I was lucky and found a 230 casting number block for the Demon. I put a 512 in the Charger and it went 11.39 with ported Edelbrocks Heads and a garbage converter. 1.72 60' Time!!!! All of these passes are at a track with 2200 feet actual elevation. The best corrected altitude was around 3300 - 3400 feet.
As you can see I am a fan of the 400 Stroker!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: fishy340]
#1482596
08/18/13 01:51 PM
08/18/13 01:51 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Partial fill, studs, and a girdle..... I would think that a 440 block set up like this should be fine up to 600.
I run a studded 230 casting 400 block. I'm only making around 510 hp though. I figure if I ever rebuild the top end to make more beans, I have a block I can work safely with.
