Newly Rebuilt Carb Bogging, WHY?
#1482183
08/09/13 07:11 PM
08/09/13 07:11 PM
Posts: 145 North East
MaxHeadroom
North East
I picked up the correct carb for my car, Carter AVS off ebay. Seller said carb ran good, but needs accelerator pump. Since I plan to rebuild the whole thing anyway, picked it up. Got it, took apart, cleaned, and rebuilt with all parts from the rebuild kit. No real issues I found, except on float not adjusted right. Accelerator pump did not look too bad either.
Put it on the car, primed it and started well, warmed up, then took it out. If I hit it, it bogs to almost stalling, recovers and runs good then. Have to feather the gas otherwise does the same. Guess this is the problem the previous owner had with it and figured it needed the acc pump, which I would have thought so too, but it still has the problem.
What am I missing? Have rebuilt several Carters in the past, never this type of problem. Car ran fine with old incorrect carb.
Any ideas?
Re: Newly Rebuilt Carb Bogging, WHY?
[Re: ]
#1482185
08/09/13 07:33 PM
08/09/13 07:33 PM
MaxHeadroom
North East
your secondaries are coming in too fast. tighten up the back secondaries. I had the same problem, loosen screw and tighten it up. problem solved, change out your accelerator pump too if your getting dribbles out of your squirter.it should shoot out nicely
I put in a new accelerator pump from the kit. What do you mean tighten up the secondaries. Loosen what? This is an original Carter AVS, not the new ones.
[Re: MaxHeadroom]
#1482186
08/09/13 08:13 PM
08/09/13 08:13 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
does the accelerator pump squirt gas as soon as you move the throttle blade?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#1482187
08/09/13 09:24 PM
08/09/13 09:24 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
On a avs there secondary air valve spring is adjustable. Tighten up till bog goes away.
JAKES AUTOMOTIVE
[Re: JAKE68]
#1482188
08/09/13 09:46 PM
08/09/13 09:46 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
As he said there is a spring that controls the tightness of the secondary air valve which is the valve at the top of the secondaries that looks like another choke. If its to loose it comes open to soon before the fuel is coming from the secondary metering system. You can tighten the spring tension to delay the secondary air valve opening to overcome the bog if thats causing your problem. Ron
[Re: 70AARcuda]
#1482189
08/10/13 10:11 AM
08/10/13 10:11 AM
MaxHeadroom
North East
Didn't check that, just assumed, but will today, thanks.
[Re: JAKE68]
#1482190
08/10/13 10:12 AM
08/10/13 10:12 AM
MaxHeadroom
North East
Thanks, will give that a shot today, never worked on an AVS, just the AFB type.
[Re: 383man]
#1482191
08/10/13 10:15 AM
08/10/13 10:15 AM
MaxHeadroom
North East
Thank you, will give that a try today, this is the first AVS I have worked on, all the others have been AFB's and there is no need for that. I have been reading up and it say maybe the spring is worn, not sure if you can buy them or what. Hopefully an adjustment will work.
