not sucking #1481887
08/09/13 12:51 AM
08/09/13 12:51 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
ok find my shorting problem, starter wire was grounding out on the tranny line's but now I am having a fuel problem, removed the old pump thinking maybe that was it an bought a new 1, nothing.. so I unhooked the fuel line at the pump that run's to the tank an hooked up a gas can, STILL AINT SUCKING!! what am I missing???
drive fast, drive hard, DRIVE MOPAR
Re: not sucking [Re: lifted85] #1481888
08/09/13 12:57 AM
08/09/13 12:57 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
what engine?
Re: not sucking [Re: lifted85] #1481889
08/09/13 01:05 AM
08/09/13 01:05 AM
The pump pushrod may be worn down (BB). Might need to pull/measure it. First I'd put 2ft of hose & a funnel on the input side & with the hose up in the air pour some gas in the hose to prime the pump
Re: not sucking [Re: RapidRobert] #1481890
08/09/13 01:13 AM
08/09/13 01:13 AM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
the block is a 74 318, I tried the ol jar an some hose, im thinking maybe electric pump would do for now .. im not sure what the guy has done to the motor, I know a tbi cam will not work with a mechanical pump with out a spacer correct??
Re: not sucking [Re: lifted85] #1481891
08/09/13 01:46 AM
08/09/13 01:46 AM
Correct, but if there is a TBI cam in there you'd think the PO would have for sure bought/installed the Hughes extension before bolting on the timing cover.
Re: not sucking [Re: RapidRobert] #1481892
08/09/13 01:59 AM
08/09/13 01:59 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Did you verify that you have a fuel pump excentric in there??
I am truckless..
