Page 3 of 4 1 2 3 4
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #1481308
08/02/14 05:49 PM
08/02/14 05:49 PM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Got mine already, gathering dust in boxes stacked in the closet. But it's good to know that replacements are available!
Re: Super Trick fans .. Rejoice ! [Re: 451Cuda] #1481309
08/04/14 02:02 AM
08/04/14 02:02 AM
NC
SLOW67 Offline
SLOW67  Offline
NC
$395 a wheel? I can get Bogarts or Holeshots for that lol
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #1481310
08/04/14 07:05 PM
08/04/14 07:05 PM
Canada
RobR Offline
RobR  Offline
Canada
I really like the super trick orig flat finish.
I use to run them back in the day but on the street they just couldn't take the roads.
I've got 3 cracked fronts up stairs in my garage,all of them cracked from the valve stem hole to a bolt hole.I just gave up trying to run them and switched over to centerline.
I'd buy a set of 4 if they had the orig embossed blue Cragar logo..without the orig center cap they just don't have that true back in the day look.IMO
Those rims back in the day were for serious street cars ..
Re: Super Trick fans .. Rejoice ! [Re: RobR] #1481311
08/05/14 03:29 PM
08/05/14 03:29 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The solid face Super Tricks and Centerline wheels are great except on deep off set rear rims you may find that when used with large diameter rear disc brakes that the inside rim diameter is too small to clear the calipers.Most of these wheels are 13" inside dia. while most discs are 14"+ at the high points of the caliper.
Re: Super Trick fans .. Rejoice ! [Re: RobR] #1481312
08/05/14 05:39 PM
08/05/14 05:39 PM
Canada
RobR Offline
RobR  Offline
Canada
Now that I see what the new trick wheels look like,they remind me of centerline wheels with bolts..
They need to have that white spun alum look..it's the white alum that draws your eye.IMO
Re: Super Trick fans .. Rejoice ! [Re: RobR] #1481313
08/05/14 11:37 PM
08/05/14 11:37 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
The pic shown looks like a 70's Super Trick to me, what's missing?
Re: Super Trick fans .. Rejoice ! [Re: LSP] #1481314
08/05/14 11:40 PM
08/05/14 11:40 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I really liked the 70's style Keystone Classics with the large center cap too, any chance of 15 x 3.5 versions of those being made? I have a 64 Savoy that's begging for a set LOL.
Re: Super Trick fans .. Rejoice ! [Re: Trick Wheels] #1481315
08/10/14 12:04 AM
08/10/14 12:04 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Hey, everybody!
Thanks for letting everyone know about Trick Wheels new, "Bolt." It is a 1-piece forging that looks exactly like a Cragar Super Trick. Tried to make it as close as possible. Even the center cap is exactly like a spun Cragar cap - just not embossed. In fact, I may emboss some later, but I like being able to "print" it. See "news" section for article on center caps.
So far, we have fronts (15"x3.5" with 1.75" b.s.). Working on rear sizes - lots of engineering drawing time and CNC programming for each size… Glad to have the first ones done. Whew!
Tim Gavern
P.S. 15"x3.5" Gyros (5-slot) and 15"x3.5" Flys are next!
trickwheels.com
Will these be stronger than the original, so more streetable?
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #1481316
08/10/14 01:31 AM
08/10/14 01:31 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
I knew if I waited long enough, they would be back in style.
Mine are Weld Zero Drags
Yeah, it's got a smallblock.
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #1481317
09/16/14 12:43 PM
09/16/14 12:43 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2540575
08/23/18 07:28 PM
08/23/18 07:28 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I wonder whatever happened to these wheels? Has anyone been able to get on the website?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2541929
08/27/18 11:12 AM
08/27/18 11:12 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I think someone got into legal trouble from what I heard and this idea is a no go now
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2616810
02/04/19 12:38 PM
02/04/19 12:38 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
For those that are fans ..
Bogart is making a very similar wheel now
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2616814
02/04/19 12:44 PM
02/04/19 12:44 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Here is a pic of the fronts, they are now street legal and are coated to retain the satin look
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2616815
02/04/19 12:48 PM
02/04/19 12:48 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Also making the Motor wheel fly look-a-likes in Satin
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2616826
02/04/19 01:00 PM
02/04/19 01:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
NEED!
'63 Dodge 330
11.19 @ 121 mph
Re: Super Trick fans .. Rejoice ! [Re: GY3] #2616843
02/04/19 01:25 PM
02/04/19 01:25 PM
moparx Offline
moparx  Offline
NEED!
i always liked those wheels ! up
beer
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2616863
02/04/19 02:09 PM
02/04/19 02:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
BigDad, those Fly's would look good on your car.
69 GTX 68 Road Runner
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2616939
02/04/19 05:03 PM
02/04/19 05:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Heck, Flys look good on any car!
The fasteners on the Tricks look different than what's on mine (hex head), but the Fly replicas look accurate.
10 years ago, I had to spend a LOT to get Mg Fly fronts & alum Fly rears. (There are VERY few Mg rears that survived.)
Real Flys also use a weird shank size, but I'm not sure about center cap diameter; Fly caps are $pendy...
Re: Super Trick fans .. Rejoice ! [Re: bigdad] #2616973
02/04/19 06:29 PM
02/04/19 06:29 PM
Cochise Co, Az, From Detroit
moetown Offline
moetown  Offline
I really like those bogart fly's. May have to get a set, if my car ever gets finished. yellow
Page 3 of 4 1 2 3 4
