Re: Super Trick fans .. Rejoice !
[Re: bigdad]
#1481310
08/04/14 07:05 PM
08/04/14 07:05 PM
Posts: 2,928 Canada
RobR
Canada
I really like the super trick orig flat finish. I use to run them back in the day but on the street they just couldn't take the roads. I've got 3 cracked fronts up stairs in my garage,all of them cracked from the valve stem hole to a bolt hole.I just gave up trying to run them and switched over to centerline. I'd buy a set of 4 if they had the orig embossed blue Cragar logo..without the orig center cap they just don't have that true back in the day look.IMO Those rims back in the day were for serious street cars ..
[Re: RobR]
#1481313
08/05/14 11:37 PM
08/05/14 11:37 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
Now that I see what the new trick wheels look like,they remind me of centerline wheels with bolts.. They need to have that white spun alum look..it's the white alum that draws your eye.IMO
The pic shown looks like a 70's Super Trick to me, what's missing?
[Re: Trick Wheels]
#1481315
08/10/14 12:04 AM
08/10/14 12:04 AM
Posts: 345 Nebraska
451Cuda
Nebraska
Hey, everybody!
Thanks for letting everyone know about Trick Wheels new, "Bolt." It is a 1-piece forging that looks exactly like a Cragar Super Trick. Tried to make it as close as possible. Even the center cap is exactly like a spun Cragar cap - just not embossed. In fact, I may emboss some later, but I like being able to "print" it. See "news" section for article on center caps.
So far, we have fronts (15"x3.5" with 1.75" b.s.). Working on rear sizes - lots of engineering drawing time and CNC programming for each size… Glad to have the first ones done. Whew!
Tim Gavern P.S. 15"x3.5" Gyros (5-slot) and 15"x3.5" Flys are next!
trickwheels.com
Will these be stronger than the original, so more streetable?
[Re: bigdad]
#1481316
08/10/14 01:31 AM
08/10/14 01:31 AM
Posts: 1,532 off the grid
340B5
off the grid
I knew if I waited long enough, they would be back in style.
Mine are Weld Zero Drags
Yeah, it's got a smallblock.
[Re: bigdad]
#2540575
08/23/18 07:28 PM
08/23/18 07:28 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I wonder whatever happened to these wheels? Has anyone been able to get on the website?
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: bigdad]
#2541929
08/27/18 11:12 AM
08/27/18 11:12 AM
Posts: 34,928 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I think someone got into legal trouble from what I heard and this idea is a no go now
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: bigdad]
#2616810
02/04/19 12:38 PM
02/04/19 12:38 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
For those that are fans ..
Bogart is making a very similar wheel now
[Re: bigdad]
#2616814
02/04/19 12:44 PM
02/04/19 12:44 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Here is a pic of the fronts, they are now street legal and are coated to retain the satin look
[Re: bigdad]
#2616815
02/04/19 12:48 PM
02/04/19 12:48 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Also making the Motor wheel fly look-a-likes in Satin
[Re: bigdad]
#2616826
02/04/19 01:00 PM
02/04/19 01:00 PM
Posts: 4,689 Wichita
GY3
Wichita
NEED!
[Re: bigdad]
#2616863
02/04/19 02:09 PM
02/04/19 02:09 PM
Posts: 10,038 MN
JERICOGTX
MN
BigDad, those Fly's would look good on your car.
69 GTX
68 Road Runner
