Having a belt squel and loud scraping type noise #1481240
08/07/13 10:12 PM
08/07/13 10:12 PM
Newberry Springs, CA
69Mannix Offline OP
69Mannix  Offline OP
Replaced the belt on the PS semd to stop, but than loud noise, tried to trace but stopped before I could get the stethoscope on all components. It is a 79 RG with a 69 340. Just seems to make belt noise. I do not want the water pump to come apart, the noise was not from the PS pump. Was making the noise just driving straight. Annoying to be sure. Is the sons 4 x 4 so want to lead him in the direction, but need a bit of help myself.
Re: Having a belt squel and loud scraping type noise [Re: 69Mannix] #1481241
08/07/13 11:00 PM
08/07/13 11:00 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
look at your damper, i've seen the outer ring go back against the timing cover . that could be the scraping sound. i saw a post a while back about a water pump eating into the timing cover on a small block also.
Re: Having a belt squel and loud scraping type noise [Re: Diplomat440] #1481242
08/08/13 01:03 AM
08/08/13 01:03 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Along those same lines, check the shield on the back of the damper that covers front seal. I've had one come loose before and make a heck of a racket.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
