Drive Shaft question #148124
11/10/08 10:37 AM
11/10/08 10:37 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
How much travel should there be between the end shaft of the transmission and the bottom of the Yoke on the drive shaft?
Re: Drive Shaft question [Re: wtucker] #148125
11/10/08 10:45 AM
11/10/08 10:45 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
You need about an inch with the vehicle at normal ride height.
jt
Yeah, it's hopped up to over 160...
Re: Drive Shaft question [Re: wtucker] #148126
11/10/08 10:45 AM
11/10/08 10:45 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Install the drive shaft into the yoke of the rear end and push it forward into the transmission till it stops, I like 3/4 to 1 inch travel.
Re: Drive Shaft question [Re: MoparforLife] #148127
11/10/08 11:32 AM
11/10/08 11:32 AM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
would an 1 3/4" be to much travel?
Re: Drive Shaft question [Re: wtucker] #148128
11/10/08 12:16 PM
11/10/08 12:16 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
It all depends on spring wrapup and rearend rotaion and body seperation.1/2 inch is fine for ladder bar and fourlink cars.If you don't have much seperation(body to rear end) you need aprox 1" to 1-1/4" if you have a lot of body lift 1-1/2" usually more than enough.If you exceed these dementions corrections are needed
Re: Drive Shaft question [Re: B G Racing] #148129
11/11/08 04:25 PM
11/11/08 04:25 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
How long is a standard OEM driveshaft for a 73 cuda?
