hoosier qtp tire pressure #1480978
08/07/13 12:33 PM
08/07/13 12:33 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
qtp 28x13.50 on a 10" wheel. anyone know what pressure works best? also when you seat the beads whats the max pressure?
Re: hoosier qtp tire pressure [Re: mopar dave] #1480979
08/07/13 12:38 PM
08/07/13 12:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Last time out mine hooked best(crappy 4 me 1.42)at 12 lbs. and I usually start at 11 lbs. and adjust from there..........
Re: hoosier qtp tire pressure [Re: Thumperdart] #1480980
08/07/13 12:51 PM
08/07/13 12:51 PM
Mt Morris Michigan
Mt Morris Michigan
ok,thanks you using caltracs or ladder bar?
Re: hoosier qtp tire pressure [Re: mopar dave] #1480981
08/07/13 01:01 PM
08/07/13 01:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I had 13.5 pounds in mine...11.5 by 28 qtp's...seemed to work extremely well there. You want as much air in them as you can get away with, that was with 002/003's. Don't want to drag flat tires down the track
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: hoosier qtp tire pressure [Re: mopar dave] #1480982
08/07/13 01:08 PM
08/07/13 01:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Dave your rear weight will dictate what it wants for
tire pressure... being that your running a wider tire
than those that posted your should be a bit lower..
testing is the only way to find out... thats a pretty
wide tire for a 10" rim
Re: hoosier qtp tire pressure [Re: MR_P_BODY] #1480983
08/07/13 01:11 PM
08/07/13 01:11 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
actually the 13.5 QTP is only 11 inches wide, the 14.5 is 12 inches, and the 11.5 is 10 inches
1.41 best 60 foot
6.56 at 104.17
Re: hoosier qtp tire pressure [Re: mopar dave] #1480984
08/07/13 01:32 PM
08/07/13 01:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Cal-tracs............
Re: hoosier qtp tire pressure [Re: Thumperdart] #1480985
08/07/13 01:45 PM
08/07/13 01:45 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
My 28x11.5 Hoosier QTP's like 13-13.5 lbs as well (with Caltracs). I've gone down to 11.5lbs, but that got scary on the big end with the slightest cross breeze.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: hoosier qtp tire pressure [Re: MR_P_BODY] #1480986
08/07/13 01:58 PM
08/07/13 01:58 PM
Mt Morris Michigan
Mt Morris Michigan
tread width is 10.75". i'll start with 13-14psi and see how it goes.
Re: hoosier qtp tire pressure [Re: mopar dave] #1480987
08/07/13 02:01 PM
08/07/13 02:01 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
1.41 best 60 foot
6.56 at 104.17
Re: hoosier qtp tire pressure [Re: mopar dave] #1480988
08/07/13 06:38 PM
08/07/13 06:38 PM
Az
Crizila Offline
Crizila  Offline
Az
Good starting point . Here is what 11 lbs looks like - with tubes - 10"rim.
Fastest 300
Re: hoosier qtp tire pressure [Re: mopar dave] #1480989
08/07/13 08:02 PM
08/07/13 08:02 PM
Macomb Michigan
65 Belv A990 Offline
Macomb Michigan
I have 31x16.50-15 QTP's (13" on the ground).The sweet spot for my junk is 12.5 psi most times. Seems to be the best compromise between a good hook and a white knuckle top end charge.
MoPower..... Better to be a racer for a moment than a spectator for a lifetime.
Re: hoosier qtp tire pressure [Re: 65 Belv A990] #1480990
08/08/13 02:21 AM
08/08/13 02:21 AM
western iowa
Z
Z_Z Offline
Z_Z  Offline
Z
western iowa
Sorry not meaning to take your post off subject, any of you guys running a manual trans with these?
Re: hoosier qtp tire pressure [Re: Z_Z] #1480991
08/08/13 04:45 AM
08/08/13 04:45 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I am. With 27 x 10,5.
But i have never been to a good track yet.
But i will on the 17th. On the bad tracks it hooks better every time i lower the prssure but at 12psi it gets scary up top so i havent been lower than that.
Re: hoosier qtp tire pressure [Re: sshemi] #1480992
08/08/13 07:43 AM
08/08/13 07:43 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I run 10 1/2 in mine , Cal - Tracs, 11.50s on a throttle stop low 1.50s 60 fts
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
