Greasing the Axle Bearings the Monoject 412 Way #1480944
08/07/13 10:58 AM
08/07/13 10:58 AM
Raleigh, NC
Meangreen68 Offline OP
Raleigh, NC
When I was in the military, they pulled all four of my wisdom teeth at the same time. The doc gave me a squirter to keep the new holes in my mouth clean.
Fast forward 23 years and I filled the MonoJect 412 with bearing grease and it works like a charm lubing axle bearings. Absolutely no mess and it fits perfectly into the gap between the rollers.
The squirter cleans up and holds up to solvents too.
I went on the internet and these things can be had for $.50 a piece
Re: Greasing the Axle Bearings the Monoject 412 Way [Re: Meangreen68] #1480945
08/07/13 11:30 AM
08/07/13 11:30 AM
SE PA
Yellow Fever Offline
SE PA
