modifying 1/2" pickup Q
#1480511
08/06/13 09:25 AM
08/06/13 09:25 AM
RapidRobert
does anyone have a source or a sugggestion for some appropriate tubing or conduit that will rethread with a 1/2" NPT die? A Lowes or Menards or similar part number would be great. Thank you for your time
Re: modifying 1/2" pickup Q
[Re: RapidRobert]
#1480512
08/06/13 03:38 PM
08/06/13 03:38 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
You should use black pipe, nut conduit or tubing That is if your talking about a 1/2 inch oil pickup in the motor, if your talking about a gas tank pick up that is different If that is the case I would use soft drawn alumimun to run to the front
[Re: dogdays]
#1480517
08/07/13 06:14 PM
08/07/13 06:14 PM
RapidRobert
I'll see what my favorite Ace hardware has in them. Taking advantage of my oiling mods & drilled the SB pump out to 1/2" NPT
[Re: Michael Ecks]
#1480521
08/08/13 06:15 PM
08/08/13 06:15 PM
RapidRobert
Yes they have a cone & I was using lubricating fluid & backing off after each twist
[Re: RapidRobert]
#1480522
08/08/13 08:45 PM
08/08/13 08:45 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
No black pipe screwed into the oil pump To much vibrations and weight for me
That's what I was worried about. Cab do you have a suggestion/part #/company for me to check out for some DOM tubing? EDIT I need a dia of tubing that can be threaded with a 1/2"NPT die I pruchased. I have a 1/2 Hemi pickup with several inches of nipple left after I cut it off & I was able to thread it some but after a few threads it seemed like the OD was on the edge of being too large as it was taking more torque to turn than I was comfortable with. That's where I am at so far.
FWIW, the Hemi pick-up does not have NPT. It is a straight pipe thread.
Let the begin.
