Well that is a hard question but they are never to their blue print spec.
Decks can be higher than spec and heads are almost a given to be several cc over spec.
so .5 to 1 number are the norm seemed farther off in the 74 to end years. so if you picked .750 as a average for below advertised compression would get you in a ball park of true numbers.
So if you were to say OK a 10.5 to one would be 9.75 to one as factory assemble you would be close.
10 to 1 maybe 9.25 to 1
8.5 to 1 7.75 to 1 .
Every motor will vary on how much it is off spec so there is no magic formula
