Froze up Sb #1479577
08/04/13 07:11 PM
08/04/13 07:11 PM
IL,USA
bdusted440 Offline OP
IL,USA
Does any body have any ideas on how to free up some stuck pistons?
Number one and two must have gotten water in them from the last owner.soaked them with pb blaster and cant get them to budge.
Re: Froze up sb [Re: bdusted440] #1479578
08/04/13 07:17 PM
08/04/13 07:17 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
PB Blaster is a joke and it stinks.. Use Aero Kroil or Marvel Mystery Oil..
I am truckless..
Re: Froze up sb [Re: 340SHORTY] #1479579
08/04/13 07:28 PM
08/04/13 07:28 PM
IL,USA
IL,USA
Ill get some mmo in the am. Anyone use kerosene in one to free it up.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
1970 v code superbee
Re: Froze up sb [Re: bdusted440] #1479580
08/04/13 07:47 PM
08/04/13 07:47 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Never knew marvel oil to be a penetrant.. but it might be.. blaster DOES work by the way.
Re: Froze up sb [Re: Hot 340] #1479581
08/04/13 07:57 PM
08/04/13 07:57 PM
PA
70Duster Offline
70Duster  Offline
PA
Another vote for Kroil.
Re: Froze up sb [Re: 70Duster] #1479582
08/04/13 08:15 PM
08/04/13 08:15 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Mix automatic trans fluid 50/50 with acetone. Soak it overnight. If it's just rust skip that mix and fill each cylinder with Evaporust, soak overnight.
Re: Froze up sb [Re: ScottSmith_Harms] #1479583
08/04/13 08:33 PM
08/04/13 08:33 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
JB80 (Justice Brothers) works better than PB in every application I've used them both in(note I didn't say PB doesn't work, just that JB80 works better). But, I've always used Marvel, poured on top and left to sit.
Re: Froze up sb [Re: 70Duster] #1479584
08/04/13 09:11 PM
08/04/13 09:11 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
When I worked for GE one of the maintenance guys set up 5 fan blades on steel shafts on the roof of the building. After 6 months he sprayed each with a different penetrating oil and let stand overnight. He beat most of them with little luck. The Kroil treated blade flew over the side of the building with the first whack. That was the only penetrent in the stock room after that.
Re: Froze up sb [Re: 74RALLYE] #1479585
08/04/13 10:27 PM
08/04/13 10:27 PM
IL,USA
IL,USA
I have to get it unfroze so I can get it apart to rebuild it.
Re: Froze up sb [Re: bdusted440] #1479586
08/04/13 11:58 PM
08/04/13 11:58 PM
IL,USA
IL,USA
So ive had trans fluid and pb blaster in the cylinders for a while now.I just went out there and she rotated! woohoo
Re: Froze up sb [Re: bdusted440] #1479587
08/05/13 12:28 AM
08/05/13 12:28 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: Froze up sb [Re: JohnRR] #1479588
08/05/13 08:04 AM
08/05/13 08:04 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
50/50 trans fluid/gas. pour it in the cyl. light it on fire. the idea is the heat will expand the cyl. allowing the trans fluid to seep down freeing the piston.
Re: Froze up sb [Re: 65rbdodge] #1479589
08/05/13 09:58 AM
08/05/13 09:58 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
That's a cool idea and even a cooler photo!
Don't mean to derail the thread but what kind of engine is that
Re: Froze up sb [Re: idrivevintage] #1479590
08/05/13 12:13 PM
08/05/13 12:13 PM
IMGTX Offline
IMGTX  Offline
Flathead V8?
Re: Froze up sb [Re: IMGTX] #1479591
08/05/13 01:46 PM
08/05/13 01:46 PM
IL,USA
IL,USA
80's roller 318. I popped the heads off and founds lots of rust in number one and two. Gaskets rusted threw. Rest of cylinders perfect. She got moisture in the front two cyls somehow. Cleaned it all up. No pitting yet. All the surfaces are good. Gonna rebuild it.So a 318 and a 340 use the same main size right? I was thinking of putting a 340 crank and rods and making a blue collar 340.Or cant it be done that way. Trying to use parts I already have.
Re: Froze up sb [Re: bdusted440] #1479592
08/05/13 01:58 PM
08/05/13 01:58 PM
IMGTX Offline
IMGTX  Offline
318 and 340 use the same main sizes but the balance is different because of the piston sizes, rod weight (318 are pressed pin 340's are often bushed floating pin) etc. Also you can not bore a 318 large enough to put 340 pistons in it.
You can have it balanced and make it work though. For the cost, it may be cheaper to buy a balanced rotating assembly since you are already gonna need pistons. It's worth looking at prices.
Re: Froze up sb [Re: bdusted440] #1479593
08/05/13 02:24 PM
08/05/13 02:24 PM
JohnRR Offline
JohnRR  Offline
318 and 340 have the same stroke , 3.31 , the difference is the 340 is forged , the 318 is not ... yes there were some 318 forged crank truck motors ... i never saw one they also share the same rod length.
Re: Froze up sb [Re: idrivevintage] #1479594
08/11/13 01:15 PM
08/11/13 01:15 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
1956 Desoto 330CI hemi
Re: Froze up sb [Re: 65rbdodge] #1479595
08/12/13 12:18 AM
08/12/13 12:18 AM
IL,USA
IL,USA
I just tried this 50/50 mix on another motor and it works!!!!1
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
Re: Froze up sb [Re: 65rbdodge] #1479596
08/12/13 10:11 AM
08/12/13 10:11 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Desoto Firedome!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
