Froze up Sb
#1479577
08/04/13 07:11 PM
08/04/13 07:11 PM
Posts: 172 IL,USA
bdusted440
IL,USA
Does any body have any ideas on how to free up some stuck pistons?
Number one and two must have gotten water in them from the last owner.soaked them with pb blaster and cant get them to budge.
Re: Froze up sb
[Re: 340SHORTY]
#1479579
08/04/13 07:28 PM
08/04/13 07:28 PM
Posts: 172 IL,USA
bdusted440
IL,USA
Ill get some mmo in the am. Anyone use kerosene in one to free it up.
currently own 1976 duster deluxe 1974 gold duster 1993 Dakota sport 2000 caravan 2002 Durango 1970 v code superbee
Re: Froze up sb
[Re: Hot 340]
#1479581
08/04/13 07:57 PM
08/04/13 07:57 PM
Posts: 1,642 PA
70Duster
PA
Re: Froze up sb
[Re: 70Duster]
#1479584
08/04/13 09:11 PM
08/04/13 09:11 PM
Posts: 1,643 A certified culture free zone.
74RALLYE
Another vote for Kroil.
When I worked for GE one of the maintenance guys set up 5 fan blades on steel shafts on the roof of the building. After 6 months he sprayed each with a different penetrating oil and let stand overnight. He beat most of them with little luck. The Kroil treated blade flew over the side of the building with the first whack. That was the only penetrent in the stock room after that.
Re: Froze up sb
[Re: bdusted440]
#1479587
08/05/13 12:28 AM
08/05/13 12:28 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
So ive had trans fluid and pb blaster in the cylinders for a while now.I just went out there and she rotated! woohoo
Re: Froze up sb
[Re: bdusted440]
#1479593
08/05/13 02:24 PM
08/05/13 02:24 PM
JohnRR
U.S.S.A.
80's roller 318. I popped the heads off and founds lots of rust in number one and two. Gaskets rusted threw. Rest of cylinders perfect. She got moisture in the front two cyls somehow. Cleaned it all up. No pitting yet. All the surfaces are good. Gonna rebuild it.So a 318 and a 340 use the same main size right? I was thinking of putting a 340 crank and rods and making a blue collar 340.Or cant it be done that way. Trying to use parts I already have.
318 and 340 have the same stroke , 3.31 , the difference is the 340 is forged , the 318 is not ... yes there were some 318 forged crank truck motors ... i never saw one they also share the same rod length.
Re: Froze up sb
[Re: idrivevintage]
#1479594
08/11/13 01:15 PM
08/11/13 01:15 PM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
That's a cool idea and even a cooler photo!
Don't mean to derail the thread but what kind of engine is that
1956 Desoto 330CI hemi
Re: Froze up sb
[Re: 65rbdodge]
#1479595
08/12/13 12:18 AM
08/12/13 12:18 AM
Posts: 172 IL,USA
bdusted440
IL,USA
I just tried this 50/50 mix on another motor and it works!!!!1
