Re: Right Angle Oil Filter Adapter- some questions
[Re: Dartslantsix]
#1479080
08/03/13 08:11 PM
08/03/13 08:11 PM
RapidRobert
Thick cork gasket inside on the bolt. Install the 90 deg adapter after the eng is in & rotate it so the filter angle is the best fit. Gasket cement SPARINGLY is fine (I would not use RTV). I like permatex MA99 (might be 99MA) "high tack" the red spray in a can. Goes on light/even & is extremely tacky & seals ver well. 50 lbs. Clean the block circular recess GOOD with a small metal bristle brush
[Re: Dartslantsix]
#1479081
08/03/13 08:12 PM
08/03/13 08:12 PM
moparpollack
Lil Herman
Lil Herman
85086
I'm installing a right angle oil filter adapter onto my small block. It's going into my 67 Barracuda. The engine is out of the car currently and I wanted to install the filter adapter before putting it into the car. Couple questions: My gasket kit came with three gaskets, but the original only had two gaskets. (big one against the block and small one under the bolt head) Where is the thick cork gasket supposed to go?
Second question: I'm not sure what angle the adapter needs to be at. Would it be best to leave it loose and then adjust it to fit once installed in the car? Is there room to get to it? Mock up your exhaust manifold for exhaust pipe clearance. On my coronet there was room yo get to it if needed.
Third question: Is there any RTV required, or should it all work fine without? No
Last question: What should I torque the bolt to? Tight to where it don't leak, that's how I did mine. Thanks!
[Re: Dartslantsix]
#1479082
08/04/13 08:53 PM
08/04/13 08:53 PM
Posts: 3,291 West Coast, USA
jbc426
West Coast, USA
I had to grind a bit of material off the body of the adapter so my socket would fit squarely over the large bolt when tightening it.
Also, make sure the adapter fits nicely into the recess in the block. Mine had to be deburred up a bit to fit right.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
