Napa gold oil filter, any issues? #1478737
08/03/13 12:43 AM
08/03/13 12:43 AM
Ohio
moparjoe360.4 Offline OP
Ohio
Is anyone else having oil pressure issues when running a Napa Gold filter? Dads 383 in his car usually carries around 80 psi cold but last year it was carrying 90-100 psi warm he swapped to a STP filter this spring when he got the car out and the pressure back to normal. So now My 360 is due for an oil change before the Nats and I can't decide if I should switch too...
Re: Napa gold oil filter, any issues? [Re: moparjoe360.4] #1478738
08/03/13 12:52 AM
08/03/13 12:52 AM
gr mich
loren kraker Offline
gr mich
napa gold were made by Wix ,dont know if they still are????? I run the golds all the time , no troubles.
Re: Napa gold oil filter, any issues? [Re: loren kraker] #1478739
08/03/13 08:38 AM
08/03/13 08:38 AM
Ohio
Ohio
As far as I know they're still made by Wix. We've run them forever with no issues till now.
Re: Napa gold oil filter, any issues? [Re: moparjoe360.4] #1478740
08/03/13 11:50 AM
08/03/13 11:50 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
they are still made by wix,only thing that I will use on all of our vehicles
Re: Napa gold oil filter, any issues? [Re: moparjoe360.4] #1478741
08/03/13 12:19 PM
08/03/13 12:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would still continue to run them.. you may have
had a bad one for what ever reason.. they are made on
a production line and anything done that way might
have a issue
Re: Napa gold oil filter, any issues? [Re: MR_P_BODY] #1478742
08/03/13 02:31 PM
08/03/13 02:31 PM
Ohio
Ohio
Thanks mr P, that was my thought too. Just wanted to make sure there wasn't anyone else having issues.
Re: Napa gold oil filter, any issues? [Re: moparjoe360.4] #1478743
08/03/13 05:48 PM
08/03/13 05:48 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
This is on the general board right now about Napa filters now made in China. Not sure if it includes the oil filters.
https://board.moparts.org/ubbthreads/show...e=1&fpart=1
