Speedo not accurate...1970 Bee
#1478601
08/02/13 09:47 PM
08/02/13 09:47 PM
Posts: 903 Saskatchewan, Canada
cudabin
I have a Red 41 tooth speedo gear which is supposed to be correct for my 26" OD, 235/60R15 tires using an A833 trans and factory 4.10 gears, however the speedo reads high by about 5 mph...
Is there any adjustment in the speedo itself, or do I just need a 43 tooth speedo gear???
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Speedo not accurate...1970 Bee
[Re: John_Kunkel]
#1478607
08/03/13 08:11 PM
08/03/13 08:11 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Always let the odometer accuracy determine the correct pinion.
I'm going to be working on a device to calibrate a mopar speedo, perhaps I can do a little business on the side... hmm.
My Duster is off a good 10 mph with the odo being spot on.
[Re: John_Kunkel]
#1478609
08/03/13 08:29 PM
08/03/13 08:29 PM
Posts: 21,841 Kirkland, Washington
Pacnorthcuda
Is your odometer accurate? If the odometer is accurate, you have a calibration problem. If the odometer is off, you have the wrong gear.
Why? I am more interested in an accurate speedo. My odo is fast, but the speedo is dead nuts on, at least up to about 80
[Re: Pacnorthcuda]
#1478610
08/03/13 08:51 PM
08/03/13 08:51 PM
gdonovan
Oakdale CT
Because the odo is gear driven, direct drive. The needle is done by a spinning magnet. Once the odo is reading correct (I verified mine by highway mile markers and GPS) it should be a simple matter to adjust the speedo to also read correct assuming you have something to drive the speedo at a fixed speed.
[Re: gdonovan]
#1478611
08/03/13 08:53 PM
08/03/13 08:53 PM
Pacnorthcuda
...and how do you adjust the speedo?
[Re: cudabin]
#1478612
08/03/13 10:18 PM
08/03/13 10:18 PM
RapidRobert
#1 get the odo correct by (in your case) a speedo gear with more teeth to slow it down. Check with GPS or 5 of the interstate mile markers in a row & they are pretty accurate. With the odo correct(ed) then if the speedo ain't correct then it needs to come out & take it in to a speedo specialty repair shop to have the magnetic gismo be recalibrated & it is something that connot be done at home. As said the speedo is DRIVEN off of & references from the odo so if the odo is off the speedo will always be off & it (that amount of error) may or may not be something you can live with. Just me I want em (odo/speedo) dead on. Those digital portable roadside MPH signs you see on occaision are a good way to check speedo accuracy. You might have to make a return trip when there's little traffic so the sign is reading your vehicle
[Re: RapidRobert]
#1478613
08/04/13 12:07 AM
08/04/13 12:07 AM
cudabin
Ok, took a small trip with my Garmin, and with the speedo showing 35mph, the GPS said 30mph which is 14% less...
At 70mph indicated on the speedo, the GPS said 62mph which is also 14% less than indicated.
The odometer at 3.1 miles only showed 3.0 on the GPS, which is 4% less than indicated.
My speedo needle fluctuates/bounces a little bit so I will replace the cable and recheck the speedo.
I am planning to put a 255/60R15 or 275/60R15 on the back, which should put the speedo closer, but the odometer would then show less than actual.
Who do you guys recommend for Speedo calibration and tick/tock/tachometer repair??
Cheers,
Arnie
[Re: Pacnorthcuda]
#1478615
08/04/13 06:15 AM
08/04/13 06:15 AM
gdonovan
Oakdale CT
*if* the gear and odo is correct a matter of adjusting the stops and spring pressure on the assembly.
You need something that can spin the assembly at a dead nuts fixed speed so where x rpm = desired speed. Most speedos are calibrated at 55 mph if I remember right.
[Re: gdonovan]
#1478616
08/04/13 05:44 PM
08/04/13 05:44 PM
Posts: 25,904 Rio Linda, CA
John_Kunkel
Rio Linda, CA
1000 rpm of the speedo cable equals 60 mph i.e. 1000 turns of the cable equals one mile on the odometer.
[Re: John_Kunkel]
#1478617
08/04/13 05:52 PM
08/04/13 05:52 PM
Pacnorthcuda
Now THAT'S an obscure factoid!!!
[Re: Pacnorthcuda]
#1478618
08/04/13 06:23 PM
08/04/13 06:23 PM
cudabin
So who do you guys recommend for the calibration and I may as well fix the tick/tock/tach as well...
Arnie
[Re: Pacnorthcuda]
#1478619
08/04/13 06:33 PM
08/04/13 06:33 PM
gdonovan
Oakdale CT
If I recall, its printed right on the speedo face on some units.
