Head question #147835
11/09/08 06:11 PM
11/09/08 06:11 PM
Nebraska
FASTBACK66 Offline OP
mopar addict
mopar addict
Nebraska
I have a 75 Powerwagon that may have a cracked head (452). My only spare complete heads are 516 off a 66 383. I don't have the down time to have hardened seats installed right now, so how long can I expect this motor to last before the heads give up.
Also, going to the closed chamber heads, will I notice much of a power gain?
Vinny
Re: Head question [Re: FASTBACK66] #147836
11/09/08 06:21 PM
11/09/08 06:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
As for the heads lasting, it may surprise you. In our experience the Mopar heads have lasted a long time with UL gas. A lot longer that either brand X heads.
Re: Head question [Re: FASTBACK66] #147837
11/09/08 07:49 PM
11/09/08 07:49 PM
w/o hardened seats it depends on how hard you run it before there's a problem & you drive like an old lady anyhow don't you Vinny so I think you'll be good.
Re: Head question [Re: RapidRobert] #147838
11/10/08 06:47 PM
11/10/08 06:47 PM
Nebraska
mopar addict
mopar addict
Nebraska
When I'm towing I sure do. Otherwise mostly speed limit in a truck like this.Think I'll run them and hope for the best.
Vinny
Re: Head question [Re: FASTBACK66] #147839
11/10/08 09:07 PM
11/10/08 09:07 PM
Vinny you'll feel the difference if you use the 516's just from the CR increase alone especially when towing where the not as good port design of them wont affect you as much at lower rpm's.
