New Denso Alternator Not Charging (FIXED IT!) #147811
11/09/08 04:29 PM
11/09/08 04:29 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Just installed a new Denso Alternator with a Charging Post and three spades for 12 Volt reference (sense), Ignition and Lamp. When looking at the face of the plug for the three spades, the ignition is the one on the far left, the sense is on the top and the lamp is on the far right...is this correct? I have the Charging wire straight to the starter relay as well as the sense wire, and the ignition wire is coming from the same source that supplied the old voltage regulator.
When I start the car the volt meter shows 12 volts, no more no less. What am I doing wrong?
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: New Denso Alternator Not Charging [Re: Junky] #147812
11/09/08 06:05 PM
11/09/08 06:05 PM
Ontario
5537SG Offline
super gas
5537SG  Offline
super gas
Ontario
it may need the light hooked up to turn it on. I suppose you could apply 12v to it, and see if that works. Its also possible you could damage it as well.
Without knowing the original intended application of the alternator, its hard to determine what inputs it requires to function.
Re: New Denso Alternator Not Charging [Re: Junky] #147813
11/09/08 07:07 PM
11/09/08 07:07 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
http://www.moparts.org/Tech/Archive/elec/34.html
edit: btw, I am using a 120A denso piece from a 97 Ram. it has a Batt post and 2 fld posts just like a stock alt.
Very simple to hook up.
Re: New Denso Alternator Not Charging [Re: RedRam] #147814
11/09/08 07:36 PM
11/09/08 07:36 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
solved the common Mopa low voltage at idle problem
I picked up a Denso alternator in the wrecking yard (Toyota 4Runner unit) and fabricated a mount to hang it from my motor plate. (I'm not selling these motor plate mounts so this isn't a for sale ad.) For the first time ever, the lights do not dim at idle. The Denso alternator is a 60 amp unit and it puts out a lot of amps at idle. My amp gauge showed 10 amps of output at 850 rpm (motor rpm). Voltage is 14.4 volts at idle with the headlights off, 14.2 with the lights on, 14.2 with high beams on.
The Denso alternator is 6 lbs lighter than the Mopar unit and is internally regulated. So one more thing gone from the firewall. I just ran the 12 volt source line that used to go the voltage regulator all the way to the alternator. Had to add one sense line so the alternator can "see" what hte voltage bus is at. This line I ran to the starter relay stud since that is where the BAT connects to as well as several other 12V sources.
AndyF
This is the way I installed mine, Toyota Denso that is. I have checked and rechecked, tested wires, you name it, all my wiring, but it still will not charge. The volt meter stays right on 12 volts. While the engine was running I tested all the wires which were right about 12 volts, I thought maybe my volt meter went bad. I even took the alternator off and had Autozone test it. It passed! I wish I knew this electrical stuff.
Someone please answer me this: Looking at the back of the alternator, where the three spades are, the one on the right is the ignition, the left is the lamp, the top is the sense. Correct? I'm not using the three wire plug. I have them wired individually.
Re: New Denso Alternator Not Charging [Re: Junky] #147815
11/09/08 07:42 PM
11/09/08 07:42 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Is this looking at the face of the plug or the back of the alternator at the three spades? I wonder if I have the ignition wire on the lamp spade?
Re: New Denso Alternator Not Charging [Re: Junky] #147816
11/09/08 07:49 PM
11/09/08 07:49 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
...Someone please answer me this: Looking at the back of the alternator, where the three spades are, the one on the right is the ignition, the left is the lamp, the top is the sense. Correct? I'm not using the three wire plug. I have them wired individually.
Going by Andy's tech archive post, you have the ign and lamp connections backwards.
Edit: your quicker than i am lol
I assume that is looking at the back of the alt.
Re: New Denso Alternator Not Charging [Re: RedRam] #147817
11/09/08 09:35 PM
11/09/08 09:35 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Great. LOL I had a 50/50 chance and got it wrong. This is why I don't gamble.
Thanks for your help.
Re: New Denso Alternator Not Charging [Re: Junky] #147818
11/09/08 09:54 PM
11/09/08 09:54 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Jeeezzzzzz, I went out, switched the wires, it works. I can't believe I didn't understand that picture.
Re: New Denso Alternator Not Charging [Re: Junky] #147819
11/09/08 10:11 PM
11/09/08 10:11 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
