Battery cutoff switch and msd, car wont die #1478075
08/01/13 09:31 PM
08/01/13 09:31 PM
Amherst,NY
challengermike Offline OP
Amherst,NY
How do you wire an msd box with a battery cut off switch and have the car shut off when the cutoff switch is flipped off. When I bought the car the msd box heavy red wire was hooked to the back of the alternator and the cutoff switch would kill the car. The msd instructions say not to hook it to the alt, I figured that is why the original box I had died. So I wired it to the off/ disconnected side of the cutoff switch and the switch wont kill the car. My car doesn't have the stock wiring but it is wired battery to the cutoff switch and everything comes off of the disconnect side of the cutoff switch. Any ideas would be great. I have tried msd's instructions of using a 4 pin ballast resister on the small red wire on the box and it didn't help. I also tried the msd's big wire to the battery directly and it did help. Im just afraid to rewire it to the back of the alt and have another box fail. If it matter's its a 2 pole cutoff switch.
Re: Battery cutoff switch and msd, car wont die [Re: challengermike] #1478076
08/01/13 09:34 PM
08/01/13 09:34 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
you need to run the alt wire back to the cut off switch.
Re: Battery cutoff switch and msd, car wont die [Re: Plymouth340] #1478077
08/01/13 09:48 PM
08/01/13 09:48 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the battery side of the master cut off switch...
Tony
70 AARCuda Vitamin C
Re: Battery cutoff switch and msd, car wont die [Re: 70AARcuda] #1478078
08/01/13 10:12 PM
08/01/13 10:12 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
The alt wire and the battery wire needs to be on the same side of the cut off switch...
Re: Battery cutoff switch and msd, car wont die [Re: Jeepmon] #1478079
08/01/13 10:51 PM
08/01/13 10:51 PM
Amherst,NY
Amherst,NY
I have tried both sides of the cutoff switch and it wont die. The alt is hooked to the disconnect side. Are you saying the alt should be wired to the battery side of the switch? I thought the cutoff switch should kill all power to the car.
Re: Battery cutoff switch and msd, car wont die [Re: challengermike] #1478080
08/02/13 12:31 AM
08/02/13 12:31 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
it wont...
been there...done that...
Tony
Re: Battery cutoff switch and msd, car wont die [Re: challengermike] #1478081
08/02/13 12:36 AM
08/02/13 12:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
All that switch is doing is cutting the battery source...
just like if you disconnect the battery in a production
car.. it continues to run... the big alt wire need
to go to the master shut off on the battery side of
the switch
Re: Battery cutoff switch and msd, car wont die [Re: MR_P_BODY] #1478082
08/02/13 01:10 AM
08/02/13 01:10 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
the switch
x2
Re: Battery cutoff switch and msd, car wont die [Re: Jeepmon] #1478083
08/02/13 03:33 AM
08/02/13 03:33 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
I put a diode in my field wire,that fixed mine
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Battery cutoff switch and msd, car wont die [Re: 6bblFLASH] #1478084
08/02/13 03:46 AM
08/02/13 03:46 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I ran a wire from my battery disconnect to a relay that powers (red or hot wire) my MSD control box. When I turn the switch off the relay is truned off, thus killing the MSD box. Just like turning the key off and a lot less amperage going though the disconnect switch. Very easy to do.
Re: Battery cutoff switch and msd, car wont die [Re: 70HemiGTX] #1478085
08/02/13 08:00 AM
08/02/13 08:00 AM
Amherst,NY
Amherst,NY
What gauge wire should I run for the alt, Its a 120 amp cs130. Right now its hooked to my starter wire which is huge.
Re: Battery cutoff switch and msd, car wont die [Re: challengermike] #1478086
08/02/13 07:47 PM
08/02/13 07:47 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
This is the tricky part.. per the spec's on a 120 amp alt, you need some stupid size wire like 4 gauge... but it will (almost) never be putting out a solid 120 amps..
So the simple answer will be the bigger, the better.. Me personally, I would go with a 10 gauge stranded wire... or even 8 gauge... if you can... That'll protect you for up to 50 and 75 amps..
Re: Battery cutoff switch and msd, car wont die [Re: Jeepmon] #1478087
08/03/13 01:12 AM
08/03/13 01:12 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
If you get a disconnect switch with 4 posts you can run the MSD cut off through it. I'll look at how I have mine wired tomorrow. I don't exactly remember how I did it. But it is much safer than running a heavy alternator wire the full length of the car and back!
Re: Battery cutoff switch and msd, car wont die [Re: 6bblFLASH] #1478088
08/03/13 02:09 AM
08/03/13 02:09 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Good idea
Yeah, it's got a smallblock.
Re: Battery cutoff switch and msd, car wont die [Re: 340B5] #1478089
08/03/13 09:56 AM
08/03/13 09:56 AM
Amherst,NY
Amherst,NY
Good idea
I may try this today. I have 1 that came with the msd box. Not sure if it will work ok with the resister but I will give it a try. I like the idea there is no power in the car with the disconnect switch off.If this doesn't work I may try running the msd off a relay.
Re: Battery cutoff switch and msd, car wont die [Re: challengermike] #1478090
08/03/13 10:28 AM
08/03/13 10:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Good idea
On the 4 post master.. I dont know how many amps it
can handle but if you ran the field wire to the small
post it will do the same(any way to turn off the alt..
but if you isolate the large alt hot lead I have never
seen a issue (using isolated clamps to hold it on
the frame)... I prefer to do it the easiest way possible
because if it brakes down at the track you want to
be able to fix it easy.. thats why I dont run a diode
or a solenoid to kill it... the old KISS system..
if you wanted you could run a 100 amp fuse at each
end of the alt lead(1 at each end would cover a short
anywhere on that line).... JMO
Re: Battery cutoff switch and msd, car wont die [Re: MR_P_BODY] #1478091
08/03/13 11:53 AM
08/03/13 11:53 AM
Amherst,NY
Amherst,NY
The diode idea didnt work I just tried it. And a solenoid wont either do to it needing a power loss to kick it off and nothing losses power with the alt powering it. I guess I will just run the alt wire and msd directly to the bat itself. I do like the idea of fuses on both sides of the alt line. And for what it's worth I tried the msd on the back of the alt and with the new box it didn't die either. Maybe because it's digital and not analog like the old box. I don't know why with the old box it would kill the car.
Re: Battery cutoff switch and msd, car wont die [Re: challengermike] #1478092
08/03/13 12:24 PM
08/03/13 12:24 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
How many wires are connected to the alt output terminal and where do they go.
If you left the factory wire that goes there, disconnect that and see if it kills it.
Re: Battery cutoff switch and msd, car wont die [Re: challengermike] #1478093
08/03/13 12:32 PM
08/03/13 12:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is your alt a single wire(hot only) or is it using
a external regulator.. if it has a external regulator
you have 2 field wires... one is a sense wire and
the other is keyed hot.. if you break the keyed hot
lead you then kill the alt... here is a simple wiring
diagram of how the system works
Re: Battery cutoff switch and msd, car wont die [Re: MR_P_BODY] #1478094
08/03/13 12:49 PM
08/03/13 12:49 PM
Amherst,NY
Amherst,NY
My alt is wired this way
S - connect this right to the "+" on the Alt. with a ring terminal
F - Not needed
L - Connect to 12V source with a 3-4 Watt bulb in the circuit (see web page on CS130 repair) I have a resister instead of the bulb
P - Not used
And the big Wire go's to my starter and back to the disconnected side of my cutoff switch.
Also on the stud the alt is 1 wire that go's to the starter, 1 wire that jump's the s terminal to the stud, and I have my cooling fans wired to it.
The alt is internally regulated GM CS130
I have no stock wiring in the car, The person I bought the car from wired it himself. The whole car is wired off the disconnect side of the cutoff switch.
