Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES!
[Re: Copper Dart]
#1477970
08/16/13 05:46 PM
08/16/13 05:46 PM
Posts: 5,160 Texas
dannysbee
Texas
You may not been around here long enough to have seen it. Eddy/Elvis would pass the hat on here every year before drag week. Half the time he didn't even have a tow rig or gas money to get there.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1477971
08/16/13 06:25 PM
08/16/13 06:25 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Where the hell is Eddie these days??? Seemed he done wore out his welcome, here????; but he sure did a good dissapearing act. Does he hang out over at YB?
[Re: dannysbee]
#1477972
08/16/13 06:29 PM
08/16/13 06:29 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Well my Dyno time should help the cause. I'm bringing the Hot Rod magazine to ask if he will autograph the article on him and his car for me. ![](/ubbthreads/images/graemlins/bow.gif) He's made a heck of a name for himself and for Mopar! You can tell he's doing something right by all the crap others throw at him. ![](/ubbthreads/images/graemlins/popcrn.gif)
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1477973
08/16/13 06:57 PM
08/16/13 06:57 PM
Quicktree
He's made a heck of a name for himself and for Mopar! You can tell he's doing something right by all the crap others throw at him. ![](/ubbthreads/images/graemlins/thumbs.gif)
oh geez his head is already to big to fit in a helmet now this ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Copper Dart]
#1477976
08/17/13 09:48 AM
08/17/13 09:48 AM
Copper Dart
I couldn't sleep much last night in anticipation of the Dyno run later today. I wasn't asked to but I'm bringing 5 gallons of REC 90 fuel with me. It's the fuel I will be using in the car from now on. After seeing what happened with the the fuel system in my '67 Satellite, I will avoid using alcohol blended fuel again. Hey, it doesn't hurt being 90 octane too! ![](/ubbthreads/images/graemlins/thumbs.gif) Around here, it runs about the same price as 92/93 octane from the pump and its available at several stations not too far from me.
[Re: Quicktree]
#1477978
08/17/13 10:10 AM
08/17/13 10:10 AM
Copper Dart
Quicktree, What's your opinion on running REC90 fuel with just under 11:1 on the street?
What say you?
[Re: Copper Dart]
#1477979
08/17/13 10:12 AM
08/17/13 10:12 AM
Quicktree
What say you?
not familiar with it. you have aluminum heads so pump gas shouldn't be an issue with the right cam/timing.
[Re: Quicktree]
#1477980
08/17/13 10:14 AM
08/17/13 10:14 AM
Copper Dart
Thanks, I did read your other post under "octane" REC90 is a non ethanol/alcohol blend fuel that most boats require so its available near most coastal and lake marina's. It smells like old school gas too, leaning a little like what I smell at the track. I think like "purple" gas?
[Re: Copper Dart]
#1477985
08/18/13 08:23 AM
08/18/13 08:23 AM
Quicktree
you should have made a post on guess the hp and give the specs on the motor
In too late to respond. Thanks Henry. Ok, I'll bite.
well start a new thread or just tell us i'll guess with the info you gave. 405hp 375tq ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Quicktree]
#1477986
08/18/13 08:50 AM
08/18/13 08:50 AM
Copper Dart
Quicktree, it's hard to believe how close you are! Did you call Elvis? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) CanYou Guess the HP? Here are the specs to the best of my ability. Started as a Stock '67 440. Mods: 0.30 over parallel and square decked to 0.0 Deck Probe forged PBP-12498-030 and file fit rings. Stealth heads, reworked valve job, *10 locks/retainers adjusted springs. Comps cam kit CL21-671-4 Nostlgia Plus 284/291 484/484 Harland Sharp rollers from Mancini 10.8:1 compression (may be 10.9) Pro Timming Gear set Edelbrock Performer ( not RPM ) Quick Fuel HR-780VS Balanced. NGK -9 REC90 fuel for all pulls. Quick tree, seeing that you made your guess already. Are you disqualified now? ![](/ubbthreads/images/graemlins/biggrin.gif)
