Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES!
[Re: Copper Dart]
#1477909
08/02/13 12:15 PM
08/02/13 12:15 PM
Posts: 2,177 ill
dennismopar73
ill
Some of my issues was resolved with just making a shim and moving the rocker arms,,Also while checking this , we measured the actual ratio and found that the proforms was not a 1-5, , so we ordered a new set of 1-5 from crane,as well as a set of 1-6,In order to get the ave of a 1-5 ratio,I needed 1-6 rocker! I guess a guy could actual just go nuts and check every rocker arm /push rod, lifter measure every cam lobe, everything to the inth degree. Make no mistake tho,just because it is a so called valued name brand that there are no issues is foolish,or just because the part is one of a cheaper caliber,does not mean that it will not work as told by the maker! For some reason most of these seasoned racers tend to have that holy than tho syndrome, and if you are not running the parts that they run you are some kind of a 'tool' . When it comes to performance parts, no one maker has the end to issues that crops up from time to time in their products, Some engine builders seam to build more into it than what is really out there. No one can say where a budget falls on this as it vairies to much from a street guy , to full out race acholic! At one point we Mopar guys wished that there was performance parts that was cheap enough to make more power out of our stuff, now we have such, and fits a lot of budgets for just about everyone,
[Re: Copper Dart]
#1477910
08/02/13 12:28 PM
08/02/13 12:28 PM
Quicktree
I can tell you this; I have a new found level of RESPECT for you guys like MR P BODY and the like! I never knew your level of dedication and commitment to go FAST! I am blown away at the costs of good performance parts. You guys either out of your minds or wealthy or a little of both. Congrats to you all with so much AIR under the wheels! WOW!!! Ricky
now that we have all that cleared up, what part of Florida?
[Re: Quicktree]
#1477911
08/02/13 12:38 PM
08/02/13 12:38 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Quicktree, Western, West Palm Beach. Loxahatchee
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1477912
08/02/13 12:40 PM
08/02/13 12:40 PM
Quicktree
cool we are up north in Jacksonville and race at Gainesville most of the time by the way nice looking car from what I see.
[Re: Copper Dart]
#1477913
08/02/13 12:46 PM
08/02/13 12:46 PM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
With that said I know what engine builder you are not using as he would never suggest that rocker.
Good luck with the build
[Re: JohnRR]
#1477914
08/02/13 12:49 PM
08/02/13 12:49 PM
Quicktree
same here
[Re: Copper Dart]
#1477915
08/02/13 01:43 PM
08/02/13 01:43 PM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'm sure we've all run "budget" parts at some time in our lives only to find out that its cheaper in the long run to spend a little more on quality products.
[Re: Stanton]
#1477916
08/02/13 05:07 PM
08/02/13 05:07 PM
Copper Dart
When "Push Comes to Shove" we are all Family under the Pentastar! I'll try to do right by my Mopar brothers (and sisters too) keeping them on the road proud.
[Re: Thumperdart]
#1477918
08/02/13 09:23 PM
08/02/13 09:23 PM
Copper Dart
It was ALOT more me than him. I'm the one trying to squeeze as much for as little. Just for the record, the HS's have been ordered and in route OUCH! Thumper dart, nice shot! Reminds me while as a younger man watching Mr. Mike Toot and his bad ass Dart's @ Miami Hollywood International Speedway.
[Re: Thumperdart]
#1477920
08/03/13 04:24 PM
08/03/13 04:24 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
Good on the HS` and it wasn`t a shot just facts............
he mighta meant nice shot(pic) of your car
[Re: Copper Dart]
#1477924
08/04/13 06:47 PM
08/04/13 06:47 PM
JohnRR
U.S.S.A.
Which Harland sharps did you get? The ones you need are only available thru Mancini , at least they were only available thru Mancini , they are bushed on the shaft instead of full roller bearing.
[Re: Copper Dart]
#1477925
08/04/13 07:52 PM
08/04/13 07:52 PM
Posts: 928 NC
SLOW67
NC
Not all of us are rich...ALL of my turbo setup has came from china, and the only part that has failed was me on the tuning end
[Re: SLOW67]
#1477926
08/04/13 09:00 PM
08/04/13 09:00 PM
Copper Dart
I haven't been informed which ones nor how much $ I will update soon. I'm so friggin excited about the Dyno Run-In I can't stand myself. I'm like continuously walking around trying to hide a woody every time I think about it.
[Re: Copper Dart]
#1477927
08/04/13 11:43 PM
08/04/13 11:43 PM
JohnRR
U.S.S.A.
Well you should find out , if he ordered the wrongs ones it's going to be more headaches.
[Re: JohnRR]
#1477928
08/05/13 12:43 PM
08/05/13 12:43 PM
Copper Dart
Wrong "Harland Sharp" Rockers? What would be considered wrong? I'm certain he knows what he's doing and I'm keeping my mouth shut and suggestions to myself. I've caused enough grief already.
