727 behind a 5.9 magnum?
#1477844
08/01/13 06:15 PM
08/01/13 06:15 PM
Posts: 51 Jacksonville, AR
dmckeehan
Jacksonville, AR
95 5.9 Magnum, is is possible to install a 727 behind it? i know it won't have overdrive, that is not an issue. What i'm wondering about it balance and torque converter fitment. thanks
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205 2002 3500 extended cab, 4x4, Cummins and 6 speed 1997 Ram 2500 5.9 with 35 Boggers - Mud Racer 1993 Dakota 4x4, Dana 60's front and rear - work in progress 1992 Dakota 2wd short bed, awaiting 440 swap
Re: 727 behind a 5.9 magnum?
[Re: dmckeehan]
#1477845
08/01/13 06:57 PM
08/01/13 06:57 PM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
You would have to use a Magnum flexplate due to the crank trigger and grind out a hole in the 727 bellhousing to clear the trigger.
[Re: gdonovan]
#1477846
08/01/13 11:30 PM
08/01/13 11:30 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
That's how it works!
You will have to open up one hole in the flexplate to bolt the converter up
