Re: SIDEWAYS CARB????
[Re: tubtar]
#1477712
08/01/13 03:37 PM
08/01/13 03:37 PM
Posts: 13,406 Marion, South Carolina [><]
an8sec70cuda
Seems to me you're trading one problem for another. With it mounted sideways, now you'll uncover the forward jets on both the primary and seconday sides. With the carb mounted normally, jet extensions on the secondaries eliminate this problem.
I've seen guys putting carb'd motors in '93-up GM F bodies (camaro/firebird) turn the carb sideways b/c it sits underneath the windshield partially. I understand when it's a packaging issue, but on a mustang this isn't a problem.
[Re: an8sec70cuda]
#1477713
08/01/13 03:44 PM
08/01/13 03:44 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
And with it sideways, now the jet extensions arent going to work.
[Re: Sport440]
#1477714
08/01/13 04:34 PM
08/01/13 04:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use to run the carbs sideways on my tunnel ram.. I made up jet extension for all the jets(had a 90* bend in each and went to the back(what is now the back) so none of the jets become uncovered... I slid the tubes into the cheapo press on jet extensions that I cut shorter... with the carbs sideways it was easier to do jet changes
[Re: MR_P_BODY]
#1477715
08/01/13 04:42 PM
08/01/13 04:42 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
use wedge floats and pump up the pressure. I'm not sure the carb builder but that is how he wants you to run his carbs
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1477716
08/01/13 07:53 PM
08/01/13 07:53 PM
Posts: 2,177 ill
dennismopar73
ill
Yes the carb builder can set it up for sideways use,it is a little different, I run mine sideways, I run alcohol, There are more reasons to run it that way than the obvious ones! Pressure on my carb Run at 7.5 # per bowl, I use a 5/8 headed bolt to set my floats,(if needed),
[Re: Chris'sBarracuda]
#1477719
08/01/13 11:39 PM
08/01/13 11:39 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
FWIW most carbs I have seen mounted sideways in a single 4 application were done for clearance issues. IE don't wanna cut up cowls etc..Not rocket science to make a sideways carb work just need to know that is what is being done. As for fuel pressure I would say that most you guys run WAY to much......
[Re: Al_Alguire]
#1477720
08/02/13 04:20 AM
08/02/13 04:20 AM
Posts: 6,150 Melbourne , Australia
LA360
I have seen a lot of guys running a single carb on Alcohol run the carb this way. I am going to try it on my own engine, but it's more because most people don't.
Alan Jones
[Re: Al_Alguire]
#1477721
08/02/13 10:23 AM
08/02/13 10:23 AM
Posts: 2,177 ill
dennismopar73
ill
I have plenty of room,I run it because # 1, my car faster that way, , Looks better,,easier to work on.
[Re: Al_Alguire]
#1477723
08/02/13 09:10 PM
08/02/13 09:10 PM
Posts: 2,864 IN
Irun5snd8th
IN
My alcohol carb was set up to run sideways and it had no sort of jet extension. It would leave with the wheels 4 feet in the air with no issues.
AFCO, Rons Fuel Injection sponsored Dodge Challenger
Mention Street Lethal Motorsports
[Re: Irun5snd8th]
#1477724
08/03/13 05:36 PM
08/03/13 05:36 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Before they closed their machine shop,some Big time Mopar racers from Norcross then Atlanta Ga mounted all of theirs and their customers side-ways they said it was worth 20-25 hp on the dyno.If I run a single carb. I would fab. up a linkage and give it a try,that would be a cheap 20-25 hp!
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1477725
08/03/13 10:05 PM
08/03/13 10:05 PM
Posts: 2,177 ill
dennismopar73
ill
That sounds close if the carbs are correctly set up to run that way . i have 1 carb set to run straight, the other set to run sideways, I pick up almost a tenth between them. I can't say that everyone can it does depend on intake and other items
