1966 Dodge Coronet Steering Column Finish #1477693
08/01/13 01:40 PM
08/01/13 01:40 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I finally scored the correct '66 only column shift setup for my silver 440 model car. The only problem is that it's green instead of black. Should I b painting it suede or gloss or? Does anyone have a paint code for me?
Thank you!
Re: 1966 Dodge Coronet Steering Column Finish [Re: Jeremiah] #1477694
08/01/13 01:45 PM
08/01/13 01:45 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Suede. Well, mine is a kind of a shiny suede. I think it is worn suede.
Sheldon
Re: 1966 Dodge Coronet Steering Column Finish [Re: RUNCHARGER] #1477695
08/01/13 02:41 PM
08/01/13 02:41 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: 1966 Dodge Coronet Steering Column Finish [Re: Lefty] #1477696
08/02/13 01:04 PM
08/02/13 01:04 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Interesting. I will take pictures of my columns (I have two '66 and one '67). They seem more shiny than suede like the dash frame.
Dig this:
http://www.dodgecharger.org/html/paint_codes.html
Re: 1966 Dodge Coronet Steering Column Finish [Re: Jeremiah] #1477697
08/02/13 01:15 PM
08/02/13 01:15 PM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
Mine was gloss.
(66' in signature picture below)
For sure gloss...with the cool chrome gear selector arm
Re: 1966 Dodge Coronet Steering Column Finish [Re: idrivevintage] #1477698
08/02/13 01:25 PM
08/02/13 01:25 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Mine is definetely glossier than the dash frame. I wouldn't call it a full gloss though. It's finish is like it was suede but it's been polished if that makes sense. It is not smooth like the door tops are.
Sheldon
Re: 1966 Dodge Coronet Steering Column Finish [Re: idrivevintage] #1477699
08/02/13 06:39 PM
08/02/13 06:39 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Mine was gloss.
That is why I was destined to find the correct steering column to replace the '67 unit in the car. Got to get rid of that tacky plastic knob having shifter lol
Re: 1966 Dodge Coronet Steering Column Finish [Re: Jeremiah] #1477700
08/04/13 01:15 PM
08/04/13 01:15 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I guess I am going with "low gloss"
Re: 1966 Dodge Coronet Steering Column Finish [Re: Jeremiah] #1477701
08/05/13 07:26 AM
08/05/13 07:26 AM
My Garage / Museum
Chrysler Plant
Chrysler Plant
My Garage / Museum
No no no
I looked for a picture of this but couldn't find a good one, I'll see if I can find something showing the gloss finish of it.
I really liked the way it looked. I drove this car daily for almost 7 years and have wiped the dust from it countless times...mine was gloss.
Fenton Mo built car if it matters, late 65' build.
Sold it recently and it went out of the area so can't get a fresh pic
Go gloss, you won't be dissapointed
Re: 1966 Dodge Coronet Steering Column Finish [Re: idrivevintage] #1477702
08/05/13 09:51 AM
08/05/13 09:51 AM
My Garage / Museum
Chrysler Plant
Chrysler Plant
My Garage / Museum
Here is the best I can come up with
A crummy low resolution picture taken from my tablet...but you can still see the reflection of the turn signal lever in the column.
Can't believe I don't have better pictures of things like this for as long as I've had it.
Cool you decided to save your Coronet I remember your post about it when you found it, it looked nice.
Any new progress pictures of it?
Regardless of whatever finish you choose it'll be a neat car
Re: 1966 Dodge Coronet Steering Column Finish [Re: idrivevintage] #1477703
08/07/13 02:37 PM
08/07/13 02:37 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thank you, I will probably hit it with some gloss for now. We got a little side tracked moving, then buying another house and moving again as we speak. Good timing as you can see.
The good news is that I have the following replacement parts piled up for the car:
vinyl top
headliner
recovered seats
electronic ignition
DMT heater box kit
REM fire wall insulation/under-dash jute
wiper pivot seals
PG Classic dash pad (total POS, might go with a dash cap)
exhaust system
replacement exhaust manifolds on the way
replacement dash cluster/glove box door/circuit board
original AM radio
new seat belts
3-spoke wood grain wheel / center cap
steering column (duh)
carpet
sill plates
package tray/jute
I think that is all of it. I have a ton of work to do before the snow flies. I'll update my project thread in the next couple of weeks. I'm thinking once the interior is done I'll pull the glass and install the vinyl top and headliner. Once that is done it will be time to decide if the car should have satin clear over the original patina or a fresh coat of buffed silver metallic.
Thank you for asking!
Re: 1966 Dodge Coronet Steering Column Finish [Re: Jeremiah] #1477704
08/07/13 06:09 PM
08/07/13 06:09 PM
usa
W
whomper1 Offline
whomper1  Offline
W
usa
my friend has an original charger and it is glossy
Re: 1966 Dodge Coronet Steering Column Finish [Re: whomper1] #1477705
08/08/13 01:59 AM
08/08/13 01:59 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Thank you, I appreciate the insight. Glossy will be much easier to spray than non-glossy. All of this good information helps make up for the pitiful dash pad I got from PG lol.
