ROLLER LIFTERS ON THE LOBE #1477682
08/01/13 01:15 PM
08/01/13 01:15 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
After taking the intake off to see why I don't have any oil pressure I noticed not all the roller are centered on the cam lobe. their not off the lobe,just not perfectly centered. Is this normal???
Re: ROLLER LIFTERS ON THE LOBE [Re: MIKES_DUSTER] #1477683
08/01/13 01:28 PM
08/01/13 01:28 PM
ill
dennismopar73 Offline
ill
Sometimes the off set of the rocker arms, can be a cam profile?
check and see if it consistant with others, if not more inspection needed!! If not call the cam maker for advise!
Re: ROLLER LIFTERS ON THE LOBE [Re: MIKES_DUSTER] #1477684
08/01/13 01:45 PM
08/01/13 01:45 PM
Your not the first to see this Block castings are not perfect so you egt what you get, that may be the reason for World to sell some of the hemi replacement blocks with lifter bores not machined into them
Re: ROLLER LIFTERS ON THE LOBE [Re: Cab_Burge] #1477685
08/01/13 01:51 PM
08/01/13 01:51 PM
It isn't with all of them,just a couple.
Re: ROLLER LIFTERS ON THE LOBE [Re: MIKES_DUSTER] #1477686
08/01/13 02:18 PM
08/01/13 02:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You would need to measure each lifter bore to see if
they are all spaced properly... and thats not likely..
but within factory limits... but yes I have seen it
on lots of my junk(maybe .015 off)
Re: ROLLER LIFTERS ON THE LOBE [Re: MR_P_BODY] #1477687
08/01/13 02:20 PM
08/01/13 02:20 PM
Thanks Mike!!!!!
