Shoulder bolt
#1477589
08/01/13 12:35 PM
08/01/13 12:35 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I am trying to help a fellow member. He wanted the shoulder bolts from my 3/4 ton full floating axle. I don't need correct bolts just bolts that will fit and he wants these from my axle. The question is, are these grade 8 or grade 5. Being it is a drive train part on a heavy truck and there are 8 slashes on the head I believe they're grade 8. I have no problem giving him these bolts just need replacements that will hold up for my truck. Normally I would just go with grade 8 but they are kind of expensive, and I need 16 of them. Thanx guys in advance.
Notice it has a smaller head and is a shoulder bolt. This is the bolt in question.
I have mechanical Aptitude. I can screw up anything.
Re: Shoulder bolt
[Re: dogdays]
#1477591
08/01/13 05:37 PM
08/01/13 05:37 PM
bboogieart
Lost and Spaced
So, 6=8 & 8=10 almost makes sense cause it doesn't make sense. Now you were right, I miss counted. Now lets all count together 1,2,3,4,5,6&7 ![](/ubbthreads/images/graemlins/shruggy.gif) go figure. ![](/ubbthreads/images/graemlins/biggrin.gif) Maybe the number is different cause of the small head. It's a 7/16th shoulder bolt with a 9/16th head.
Re: Shoulder bolt
[Re: bboogieart]
#1477592
08/02/13 12:33 AM
08/02/13 12:33 AM
Posts: 10,672 Freeport IL USA
poorboy
Freeport IL USA
I would put grade 8 bolts AND grade 8 flat washers if your going to do away with the original shouldered bolts. The old rear ends had tapered sleeves that locked the axle to the hub, that was the reason for the shouldered bolt, you will need the flat washer to lock the sleeve and not damage the bolt head. Its only money, you can't take it with you. ![](/ubbthreads/images/graemlins/biggrin.gif) Gene
Re: Shoulder bolt
[Re: 76dodgeboy]
#1477602
08/02/13 01:19 PM
08/02/13 01:19 PM
bboogieart
Lost and Spaced
In my county "beat him up" = 6 months on huber if your lucky. Doesn't matter if he is trespassing, or thieving, or what ever. Of course I wasn't really serious about killing some one, in case anybody is concerned.
