Re: Timing chain slip
[Re: dnd0001]
#1477370
07/31/13 11:29 PM
07/31/13 11:29 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Did it get a real TC or a nylon 1 ???
I am truckless..
[Re: 340SHORTY]
#1477371
08/01/13 12:00 AM
08/01/13 12:00 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
My finger is long enough that if I pull the fuel pump on an LA I can push on the timing chain and feel the slack. However, I would assume you replaced the timing chain when you went thru the engine so it shouldn't have slack. I forget the spec for slack in the chain, but the FSM should have it.
I forget how many degrees off one tooth is, 37 comes to mind but I could be wrong. One thing to remember is that if it gets far enough off you can bend valves. I would not try to run it until you verify the cam timing is correct. This mean you will have to pull the timing cover.
[Re: dnd0001]
#1477372
08/01/13 12:19 AM
08/01/13 12:19 AM
RapidRobert
That is not alot of questions . Get the ten dollar tool that fits in the spark plug hole & find/get the piston at exact TDC & at that point see if the dampener timing slit is within a degree or two of zero on the timing tab. this'll tell you if the dampener has or has not slipped. Pull the plugs to make turning easier & with a 1&1/4" socket/ breaker bar turn the crank till either the #1 or the #6 cyls' rocker arms are both moving & open the same distance (rock back/forth & get em equal) & at that point see if the dampener slit is within a degree or two of being at zero on the timing tab which will tell you if the timing chain has or has not jumped a tooth. Holler back with any news. EDIT Faster yet (Assuming the dampener ain't slipped which that is rare) & it did die when running & even if the dampener slipped when going down the road that would not cause it to die, put the timing mark slit on zero (TDC) on the timing tab & the rotor should be right at or very close to either the #1 or #6 plug wire dist cap terminal. That'll give you an answer in no time
[Re: dnd0001]
#1477374
08/01/13 10:47 AM
08/01/13 10:47 AM
Posts: 2,177 ill
dennismopar73
ill
slack is easy to tell,just take the balancer turn one direction then the other, look how much it moves, you will feel the slack in the chain if it has any! it should be almost nil! All chains will have some, but close to 1 - 2* is normal I would think,?? If it has movement,take chain out replace it! There are companies out there that make a slack adj tensor for loose chains too
[Re: GTX MATT]
#1477377
08/01/13 11:26 AM
08/01/13 11:26 AM
Posts: 530 SW CO
HemiSportFury
SW CO
Did you verify that the distributor is locked down tight and did not slip position while you were driving? Did you check the rotor position before this happened?
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: dnd0001]
#1477379
08/01/13 02:28 PM
08/01/13 02:28 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
I will try and answer all the questions.
No nylon timing gears. I too thought the distributor slipped while driving as well. I used a compression tester to get on the compression stroke and adjusted it to TDC on the damper. I then pulled the distributor and the gear slot is pointing straight forward. It should be pointing at #1. Before pulling the distributor the rotor was pointing off towards #4. Do not know if the distributor was lose before hand. The distributor gear is pointing off straight when I'm at TDC on the damper that is what is making me thinks its the chain. Thought I heard something raddling, not sure where from. I have check the MSD system very closely. Even replace the pickup, new cap, box and rotor. its only 1 year old and has very little rust. all is loose. The damper gos to 50 and with the car at idle and the ignition light its about 45-46 on the damper. Don't want to take it apart until I've pulled the fuel pump and checked the chain tension and look inside with a borscope camera. Im also going to use the camera to check each cylinder for any damage of a slipped chain. Will pull valve covers to make sure I'm at TDC and not rely on the damper so much. Or go and get the TDC tool.
You need to mechaincally confirm TDC with a stop because it's possible your balancer may have slipped ... not that a slipped balancer would have caused the engine to die like it did .
[Re: dnd0001]
#1477383
08/01/13 09:02 PM
08/01/13 09:02 PM
RapidRobert
So the damper looks to be OK. and stick a camera in there to see what I can see just to make sure.
Progress! It appears that the dampener is Ok. The camera would help you see any damage & I'm sure you could stick something in there to feel for excessive slack but I would suggest with the dampener slit on TDC on the tab (which you're close to now) that if you're on #1 compression to remove the pass valve cover & turn the crank a bit back & forth till both of #6's rockers are moving/& equal height which is "rockover" & at that point if the chain ain't slipped the dampener will be within a degree or two of TDC on the tab. If with the dampener on TDC of the tab (which you're close to now) if the #1 cyl is on overlap rather than compression then pull the drivers valve cover & get the #1 cyls' rocker arms on "rockover" & at that point same deal see if the dampener slit is within a degree or two of TDC on the tab. If so it ain't slipped. If all is well (no jumped chain) you might not be exactly within a degree of two depending on if its an asymetrical lobe cam and or if it's been advanced but as far as it is off from normal "rockover" is going to tell us something significant here
[Re: dodgeboy11]
#1477385
08/02/13 07:10 PM
08/02/13 07:10 PM
Posts: 88 Minnesota, USA
dnd0001
Minnesota, USA
I took off both valve covers. Put it on TDC on the compression stroke on #1. Looked at #6 and turned it back and forth until even. one will be going up and the other down and try to stop when they are even? Is that correct? If so I'm showing about 16 degrees off TDC. Both valves on #1 are closed. The distibutor is not on #1. It's between #1 and #8. The car was running at that setting.
I think next I will put it on #6 compression stroke and see if with the camera the two marks are lined up. If nothing else
check the chain for tension. I too thought about the sproket slipping on the pit. I will pull the fuel pump and see what I see. Just need to make sure I did the rock over correctly?
Car running the oil pressure is good unless it slipped and went back in and started to work. I will pull the timing gear and see what the end looks like.
By the way I put the borscope down each spark plug hole and didn't see any marks from valves. But the pistons have recesses for the valves.
[Re: dnd0001]
#1477386
08/03/13 12:47 AM
08/03/13 12:47 AM
RapidRobert
I took off both valve covers. Put it on TDC on the compression stroke on #1. Looked at #6 and turned it back and forth until even. one will be going up and the other down and try to stop when they are even? Is that correct? If so I'm showing about 16 degrees off TDC. Both valves on #1 are closed. The distibutor is not on #1. It's between #1 and #8. The car was running at that setting. Just need to make sure I did the rock over correctly?
Yes you did rockover correct. It would appear? that the chain or something has slipped (I still dont think it's the chain) just because you were cruising down the road when it happened but... If the borescope will let you see if you're on dot to dot (6/12 o'clock) with the dampener slit on TDC then yes take advantage of the tool. I've wanted one of those & now I really want one
