Re: double flaring tool
[Re: Quicktree]
#1477317
07/31/13 11:17 PM
07/31/13 11:17 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
the one from summit works fine, there is an art to it. practice a few times
I got one from an Army mechanic over yonder and I have to believe it was a good one.....expensive one at any rate. But it took me a few tries to get " good " with it. With practice , it becomes a lot easier.
Re: double flaring toole
[Re: MR_P_BODY]
#1477321
08/01/13 08:51 AM
08/01/13 08:51 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Mine is a Blue Point I got from the SnapOn guy.Its probally 30 years old and made thousands of flares.The Rigid is a nice piece.My kid bought a Summit one because it was on clearance at under 10 bucks.It works great for him.As Mr P said they have to be tight or the tube will just move out the other end.Rocky
Chrysler Firepower
[Re: therocks]
#1477322
08/01/13 08:59 AM
08/01/13 08:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I will tell you also that you can make hose beads with the flairing kit... put the tube in to the length as if your doing a flair .. using the double flair button turn it down 1 1/2 turns and you have a hose bead ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Jet Doc]
#1477324
08/01/13 10:55 AM
08/01/13 10:55 AM
MR_P_BODY
For some reason that brake line with the dark coating like you have is a real hassle to flare. If you can find the silver line instead, it's way easier to flare (NAPA).
That coating is epoxy which most companies are going with ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Jet Doc]
#1477327
08/01/13 01:48 PM
08/01/13 01:48 PM
Posts: 295 Vallejo, CA
ditchdrift
Vallejo, CA
i find the poly coated lines much easier to cut, bend, and flare than the standard galvanized line.
[Re: 135sohc]
#1477329
08/01/13 05:48 PM
08/01/13 05:48 PM
Posts: 240 Spring City , Pa.
SIKPUP
Spring City , Pa.
I have the eastwood one with the turret head, saddle clamp and the long handle. Time/hassle it has saved was worth every penny of the cost.
![](/ubbthreads/images/graemlins/iagree.gif)
