starter removal.. #1477298
07/31/13 10:13 PM
07/31/13 10:13 PM
Cincinnati Ohio USA
Moeggenpar Offline OP
Cincinnati Ohio USA
I'm having trouble removing the original starter on my 68'383 Charger.I've got the cables and the bottom mounting nut off,but where is the other attachment point? Thanks for any info.
Re: starter removal.. [Re: Moeggenpar] #1477299
07/31/13 10:15 PM
07/31/13 10:15 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
its on the top inline with the bottom,
Re: starter removal.. [Re: Moeggenpar] #1477300
07/31/13 10:18 PM
07/31/13 10:18 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Directly on top of the bottom one. It's sort of hard to see and get at. I have a short wrench that works pretty good, not much room to move a long wrench in there.
Re: starter removal.. [Re: bonefish] #1477301
07/31/13 10:20 PM
07/31/13 10:20 PM
Cincinnati Ohio USA
Cincinnati Ohio USA
thanks. Is it hard to access?
Re: starter removal.. [Re: pinkduster] #1477302
07/31/13 10:23 PM
07/31/13 10:23 PM
Cincinnati Ohio USA
Cincinnati Ohio USA
Directly on top of the bottom one. It's sort of hard to see and get at. I have a short wrench that works pretty good, not much room to move a long wrench in there. Thanks for the replies
Re: starter removal.. [Re: Moeggenpar] #1477303
07/31/13 10:29 PM
07/31/13 10:29 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just use a extetion on a 3/8 drive ratchet,the ex. should be about as long as the starter.
Re: starter removal.. [Re: bonefish] #1477304
07/31/13 11:08 PM
07/31/13 11:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Me too.
I have mechanical Aptitude.
I can screw up anything.
Re: starter removal.. [Re: bonefish] #1477305
07/31/13 11:11 PM
07/31/13 11:11 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Yes, I've done it that way already too, but sometimes the exhaust can cause problems with that method. No doubt, sometimes, changing starters can be a major p.i.t.a..
Re: starter removal.. [Re: Moeggenpar] #1477306
08/01/13 07:57 PM
08/01/13 07:57 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Don't forget to disconnect the battery
