Lockup converter into a 727?
#1476864
07/31/13 08:54 AM
07/31/13 08:54 AM
Posts: 96 Nampa, Idaho
Wyle E Coyote
Nampa, Idaho
I'm sure this has been covered before, but I couldn't find recent evidence of it in the search area. I want to know if a locking torque converter can be made to work in a 727. I now have an International TravelAll with the "727" in it, (special case to match the IH engine bolt pattern and made to accept a GM starter on the passenger's side), and I could use one more gear for highway travel. I've looked at overdrive transmissions, add-on boxes such as Gear Vendors, and everything is expensive and extensive to convert. Then I remembered something; for a brief period of time, didn't the 727's have a locking torque converter in them, before they built the actual overdrive equipped transmissions (A-500 and 508, or R46H)? If so, and if it's something I can make work, it may be the answer to my issue. Or is it that I'm just screwed? ![](/ubbthreads/images/graemlins/laugh2.gif) Thanks everyone! ![](/ubbthreads/images/graemlins/coool.gif)
25 Dodge Roadster 66 D100 440/727 (on 72 D100 chassis) 67 W200 360/727 72 IH TravelAll 1110 4x4 345/727/NP205 76 Scout 2 360/727/D20 '08 Dakota SLT Quad Cab 4wd 4.7L
Re: Lockup converter into a 727?
[Re: Wyle E Coyote]
#1476865
07/31/13 08:59 AM
07/31/13 08:59 AM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
you cant just put a lock up converter in the trans there is more to it than that.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: Wyle E Coyote]
#1476867
07/31/13 09:55 AM
07/31/13 09:55 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I put an A999 in the Cuda. It is virtually identical to the 904 it replaced. There is another hydraulic circuit to activate the locking mechanism. It has an extra valve on the top of the valve body to control the lockup and some new passageways for the fluid to get to the converter. BTW, the 999 does not have O/D, just lockup converter. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: meep_meep]
#1476870
07/31/13 04:53 PM
07/31/13 04:53 PM
Posts: 75,095 A Banana Republic near you.
JohnRR
simply installing a lock up type converter will not give you another gear..The transmission must have the 4th/overdrive gear also for it to work...
This is not correct, before there was the 4 speed overdrives based on the 727/904 there was a lockup converter used on the 727/904. The activation of the lockup was different on the 727/904 vs. the OD variants.
You do not need to have an OD trans to have a lockup converter but you can not put a lockup converter on a NON lockup trans because the input is different , plus it has a different spline count.
[Re: JohnRR]
#1476871
07/31/13 05:11 PM
07/31/13 05:11 PM
Posts: 100 Tennessee
meep_meep
Tennessee
no...my statement is correct pertaining to the OP's question...which was can i put a lock up converter in because "i could use another gear on the highway"....the 727 locking converter did not give you another gear, it simply locked up 3rd/final gear...he's asking if adding a locking converter will give him another gear, which it will not do...
[Re: meep_meep]
#1476872
07/31/13 05:15 PM
07/31/13 05:15 PM
JohnRR
What I bolded above reads ... to me ... like you are saying that using a lockup converter requires an OD trans .
[Re: JohnRR]
#1476873
07/31/13 05:23 PM
07/31/13 05:23 PM
Wyle E Coyote
Nampa, Idaho
Yeah, I know that a locking converter doesn't give me another "gear" specifically, though I do know they reduce your RPM's. I was hopeful that there was a way to do it, but I wasn't sure. At this rate, I'm looking at about $1500 to go with a 4L80 swap (including adapter kit and some fab for new mount, etc.), or over $3,000 for a gear vendors unit. I guess I have some more research to do. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Thanks guys! ![](/ubbthreads/images/graemlins/coool.gif)
[Re: Wyle E Coyote]
#1476874
07/31/13 06:01 PM
07/31/13 06:01 PM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Another issue previously unmentioned is the case, the lockup case is larger inside to provide clearance for the lockup module on the valve body...merely adding the pump and input shaft won't make a pre-'87 727 into a lockup.
Not sure if the Cornbinder case was ever configured for lockup.
[Re: John_Kunkel]
#1476875
08/01/13 01:43 PM
08/01/13 01:43 PM
Wyle E Coyote
Nampa, Idaho
Yeah, to my knowledge they weren't. Back in the day, if you wanted an overdrive setup, you could order the 5 speed manual. They were the ones used in the school busses as well. T98 and 99 if memory serves me. One was a 5 speed with direct 5th, and one was overdrive 5th. I'd consider that route if it weren't for two reasons:
1.) I drive a truck for a living, so when I get in my personal rig, the last thing I want to do is row the boat some more.
2.) I want to wife to enjoy driving it if she needs to use it. She's ok with a manual, but if it gets too truck-like, she will avoid it at all costs.
Then again,... If I went with a 5 & 4 combo with twin sticks,... that would be interesting. ![](/ubbthreads/images/graemlins/thumbs.gif)
