Re: 1970 b-body power disc brake booster/master cylinde
[Re: UP FM3challenger]
#147696
11/16/08 09:28 PM
11/16/08 09:28 PM
Posts: 18,165 Mass
DAYCLONA
Mass
#147697
11/16/08 09:30 PM
11/16/08 09:30 PM
Posts: 18,165 Mass
DAYCLONA
Mass
[Re: JohnRR]
#147698
11/16/08 09:32 PM
11/16/08 09:32 PM
Posts: 18,165 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#147699
11/16/08 10:07 PM
11/16/08 10:07 PM
Posts: 75,276 A gulag near you.
JohnRR
A gulag near you.
This is an original , that is not painted the color it should be .
fixed
[Re: JohnRR]
#147700
11/17/08 01:59 AM
11/17/08 01:59 AM
Posts: 4,086 Strathroy, Ontario
BS27R1B
Strathroy, Ontario
Can anyone post the correct casting numbers for the master cylinders?
E B Hemi and non hemi.
'.. it was long ago and it was far away, and it was so much better than it is today..' Jim Steinman
[Re: BS27R1B]
#147701
11/17/08 02:14 AM
11/17/08 02:14 AM
Posts: 8,342 Crook County, ILL
Mastershake340
Crook County, ILL
List of disc brake casting numbers from my master cylinder article published in Mopar Action April '05: Disc brake master cylinder casting numbers Note: first casting number in list should be 2225541
[Re: NANKET]
#147703
11/17/08 02:17 AM
11/17/08 02:17 AM
Mastershake340
Crook County, ILL
Where do we buy a rebuild kit for the original 1970 engine side master cylinder?
Napa and Raybestos have a kit for 1-1/8" bore master cylinders.
[Re: ademon]
#147705
11/18/08 12:14 AM
11/18/08 12:14 AM
Posts: 6,569 Abilene, Texas
fastmark
Abilene, Texas
I know Galen makes mistakes, but both of these birds have nice lines on them and pretty obvious that they have the original masters on them. 20 or 30 years ago when someone bought the wrong master and just twisted the lines over on the other side, they did not tend to do a good job at making them look straight. I believe both cars have the original lines in the correct orientation and yet they are both 440 cars with lines on opposite sides. Another thing that you probably will not agree on is the fact that neither of my friends two Superbirds had the vin number stamped on the rad support. Both had it on the trunk lip. Again, Galen said that was common on Superbirds. The problem is that I mentioned Galen and people on this board love to throw stones at him. That my 2 cents worth.
When I first bought my bird in 1979, I went to the Chrysler dealership and bought three masters for my AAR cuda and three for my 440 Superbird. All of the ones for the bird came with the lines to the engine side
[Re: fastmark]
#147706
11/18/08 09:57 AM
11/18/08 09:57 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
On that one I have to agree with you.My bird has none and a friends B5 bird also nas none.
