oil pressure cut off switch #1476366
07/30/13 08:00 AM
07/30/13 08:00 AM
Can , Nova Scotia , Cape Breto...
caper Offline OP
caper  Offline OP
A friend of mine is looking for a switch to cut off the ignition when oil pressure is less than 20 lbs. What are you using? part #, and where to get it?
thanks
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: oil pressure cut off switch [Re: caper] #1476367
07/30/13 04:10 PM
07/30/13 04:10 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
thanks
Here you go, available from Jegs..
Oil Pressure Safety Switch
555-11200
1/8" NPT
Shuts off when under 5 psi
$21.99
http://www.jegs.com/p/JEGS/JEGS-Oil-Pressure-Safety-Switch/934233/10002/-1
Just my $0.02....
Re: oil pressure cut off switch [Re: caper] #1476368
07/30/13 04:36 PM
07/30/13 04:36 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
thanks
If you wire it into the ignition you'll have to flip a switch every time to start it and flip it back so it works.
I just wire mine into the shift light.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: oil pressure cut off switch [Re: d7cook] #1476369
07/30/13 04:51 PM
07/30/13 04:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks
You can still crank the engine with it... it just
wont fire till it reaches the kill pressure
Re: oil pressure cut off switch [Re: MR_P_BODY] #1476370
07/30/13 05:12 PM
07/30/13 05:12 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
thanks
I never considered that. Depends on what you have though too. My current motor with an external suction line will not make oil pressure when cranking.
Re: oil pressure cut off switch [Re: d7cook] #1476371
07/31/13 09:28 PM
07/31/13 09:28 PM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
I use this one:
http://www.summitracing.com/parts/mrg-7872/overview/
It's a three prong setup NO/NC that trips at 15psi. You wire your start circuit to the NC side so the pump runs immediately while cranking and fills the carb(s), the NO side to the ignition circuit for the safety feature while running, and the output to the pump or pump relay. There is a wiring diagram that shows this. Be sure that the switch has enough current capacity to run your pump if you don't use a relay. I've run the Mallory 140 on my RoadRunner directly through the switch for years with no problem, but a bigger pump would need a relay. Works great and gives a little more protection that a 5 psi switch.
Scott
