rad cap different puke tank or without ? #1475805
07/29/13 09:14 AM
07/29/13 09:14 AM
Frederiction. New Brunswick ,C...
RTshaker Offline OP
RTshaker  Offline OP
Does stock 15 # rad cap from a 70 with no puke tank release fluid differently than a 74 car with the tank. Thanks
Re: rad cap different puke tank or without ? [Re: RTshaker] #1475806
07/29/13 09:43 AM
07/29/13 09:43 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
yes
Re: rad cap different puke tank or without ? [Re: 05dakota] #1475807
07/29/13 10:41 AM
07/29/13 10:41 AM
RTshaker Offline OP
RTshaker  Offline OP
how so ? how do I physically see the difference between the two caps
Re: rad cap different puke tank or without ? [Re: RTshaker] #1475808
07/29/13 10:47 AM
07/29/13 10:47 AM
A coolant recovery cap (used with the puke tank) will have a thin brass disc on the bottom of the black seal & it will be loose.
