Re: Boost is GOOD!!!
[Re: quickd100]
#1475383
07/31/13 11:43 AM
07/31/13 11:43 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
How much boost, how much timing?
If the tuneup caused the head gasket failure, and you put good head gaskets and studs in it... the next weak link part that fails won't be so forgiving.
Cam straight up, felpro 1008 gaskets, head bolt/stud upgrade. Sneak up on the tune, and it will be fine.
Either get it on the dyno, or take it to the track. Start with safe timing and add a degree at a time. Watch the HP or mph, and find out what it likes.
[Re: dizuster]
#1475384
07/31/13 06:58 PM
07/31/13 06:58 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
It is on my dyno, I'll be installing some better gaskets, drop the timing back a bit more, and installing a softer spring in the waste gate. Dave
[Re: 72swgnr]
#1475387
07/31/13 07:38 PM
07/31/13 07:38 PM
quickd100
nielsville, minn.
Feel free to use my intake if you want to try some different things. Also you can slap on my heads if you want as long as you promise not to destroy them
Zeb; Can you more closely define DESTROY . Don't worry, I'm not planing on pirating any of your parts. Well maybe your old MP cam later. Dad ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 72swgnr]
#1475389
08/02/13 12:34 AM
08/02/13 12:34 AM
Posts: 6,020 Salem
Grizzly
Moparts Proctologist
Salem
Does this turbo have a carbon seal?
Would you mind posting a link to the ebay seller?
Thanks!
Mo' Farts
Moderated by "tbagger".
[Re: dizuster]
#1475393
08/02/13 09:47 AM
08/02/13 09:47 AM
quickd100
nielsville, minn.
Whoa...the exhaust back pressure is probably insane on that turbo on a 318"!!! That might have been part of your hg issue right there.
You should have bought two of those turbos. .lol
The purpose of the whole build is to just give a little smogger motor a little kick in the pants. I'm not looking to make a 500hp fire breathing bb killer. Set up as it is though it makes almost as much hp at 2000rpm as it did na. It probably would get off the dyno alive if I push it much harder, the machinist?? that built it liked to grind notches in the rod beams to mark which side faced out. I'm hoping to have some gaskets by midle of next week, phase II will then start on the 318 torture test.Dave (Mods, we need a little mushroom cloud icion) ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: quickd100]
#1475394
08/02/13 10:05 AM
08/02/13 10:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Notches in the rods.... thats gonna hurt.... BOOM ![](/ubbthreads/images/graemlins/wave.gif)
[Re: 72swgnr]
#1475397
08/02/13 01:25 PM
08/02/13 01:25 PM
Posts: 4,258 Canada
WO23Coronet
Canada
Here's a pic of the setup. It was only intended to fit on the dyno
The good thing is, when you're done killing it on the dyno, you could sell that set up to the extreme rat rod guys, they would buy it in a second, it would match their 6 foot tall shifters with that thermoquad up in the air like that.
Seriously, I like it when guys post stuff like this, how come you went draw through instead of blow through?
[Re: WO23Coronet]
#1475398
08/02/13 02:43 PM
08/02/13 02:43 PM
quickd100
nielsville, minn.
Pure Lazyness. Less mods to the carb, don't have to boost reference the fuel pump and it cost next to nothing, (for me anyway). My biggest worry was a backfire through the intake tract, so far it hasn't been an issue. My gaskets showed up today too. I ordered them from Jegs and the person taking my order is a memeber here on Moparts. Forgive me but I can't remember his handle but his extension at Jegs is #277. If the motor survives I'll refabricate the intake tract moving the carb over and lower to fit under the hood.Dave ![](/ubbthreads/images/graemlins/wrench.gif)
[Re: quickd100]
#1475399
08/03/13 12:22 AM
08/03/13 12:22 AM
Posts: 6,020 Salem
Grizzly
Salem
One more question: How is the timing set up?
Mo' Farts
