Re: Boost is GOOD!!! [Re: quickd100] #1475383
07/31/13 11:43 AM
07/31/13 11:43 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
How much boost, how much timing?
If the tuneup caused the head gasket failure, and you put good head gaskets and studs in it... the next weak link part that fails won't be so forgiving.
Cam straight up, felpro 1008 gaskets, head bolt/stud upgrade. Sneak up on the tune, and it will be fine.
Either get it on the dyno, or take it to the track. Start with safe timing and add a degree at a time. Watch the HP or mph, and find out what it likes.
Re: Boost is GOOD!!! [Re: dizuster] #1475384
07/31/13 06:58 PM
07/31/13 06:58 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
It is on my dyno, I'll be installing some better gaskets, drop the timing back a bit more, and installing a softer spring in the waste gate. Dave
Re: Boost is GOOD!!! [Re: quickd100] #1475385
07/31/13 07:05 PM
07/31/13 07:05 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
Feel free to use my intake if you want to try some different things. Also you can slap on my heads if you want as long as you promise not to destroy them
Re: Boost is GOOD!!! [Re: 72swgnr] #1475386
07/31/13 07:14 PM
07/31/13 07:14 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
LOL now that's funny !!
Re: Boost is GOOD!!! [Re: 72swgnr] #1475387
07/31/13 07:38 PM
07/31/13 07:38 PM
nielsville, minn.
Q
Q
nielsville, minn.
Zeb; Can you more closely define DESTROY . Don't worry, I'm not planing on pirating any of your parts. Well maybe your old MP cam later. Dad
Re: Boost is GOOD!!! [Re: quickd100] #1475388
07/31/13 07:41 PM
07/31/13 07:41 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
Go ahead and use whatever you want. It's just sitting there not being used.
Re: Boost is GOOD!!! [Re: 72swgnr] #1475389
08/02/13 12:34 AM
08/02/13 12:34 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Does this turbo have a carbon seal?
Would you mind posting a link to the ebay seller?
Thanks!
Mo' Farts
Moderated by "tbagger".
Re: Boost is GOOD!!! [Re: Grizzly] #1475390
08/02/13 07:32 AM
08/02/13 07:32 AM
nielsville, minn.
Q
Q
nielsville, minn.
Thanks!
Don't know about the seal, at that price I doubt it, I wasn't looking for a 100,000 mile unit. Here's a link for the same turbo, don't know if it's the same seller though. Dave
http://www.ebay.com/itm/T3-T4-T04E-Turbo...#ht_4223wt_1006
Re: Boost is GOOD!!! [Re: quickd100] #1475391
08/02/13 07:52 AM
08/02/13 07:52 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Whoa...the exhaust back pressure is probably insane on that turbo on a 318"!!! That might have been part of your hg issue right there.
You should have bought two of those turbos. .lol
Re: Boost is GOOD!!! [Re: quickd100] #1475392
08/02/13 09:00 AM
08/02/13 09:00 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Thanks Dave.
I was looking to do the same thing to my 318 when a turbo and 4bbl from a 301 Pontiac was in the local classifieds. Nice thing about the pontiac turbo is it's already set up for draw-through. He sold it though, might give this ebay one a try......
Mo' Farts
Re: Boost is GOOD!!! [Re: dizuster] #1475393
08/02/13 09:47 AM
08/02/13 09:47 AM
nielsville, minn.
Q
Q
nielsville, minn.
The purpose of the whole build is to just give a little smogger motor a little kick in the pants. I'm not looking to make a 500hp fire breathing bb killer. Set up as it is though it makes almost as much hp at 2000rpm as it did na. It probably would get off the dyno alive if I push it much harder, the machinist?? that built it liked to grind notches in the rod beams to mark which side faced out. I'm hoping to have some gaskets by midle of next week, phase II will then start on the 318 torture test.Dave
(Mods, we need a little mushroom cloud icion)
Re: Boost is GOOD!!! [Re: quickd100] #1475394
08/02/13 10:05 AM
08/02/13 10:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Notches in the rods.... thats gonna hurt.... BOOM
Re: Boost is GOOD!!! [Re: MR_P_BODY] #1475395
08/02/13 12:28 PM
08/02/13 12:28 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Would LOVE to see some pics of this set up! PLEASE...
Re: Boost is GOOD!!! [Re: cudadoug] #1475396
08/02/13 12:36 PM
08/02/13 12:36 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
Here's a pic of the setup. It was only intended to fit on the dyno
Re: Boost is GOOD!!! [Re: 72swgnr] #1475397
08/02/13 01:25 PM
08/02/13 01:25 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The good thing is, when you're done killing it on the dyno, you could sell that set up to the extreme rat rod guys, they would buy it in a second, it would match their 6 foot tall shifters with that thermoquad up in the air like that.
Seriously, I like it when guys post stuff like this, how come you went draw through instead of blow through?
Re: Boost is GOOD!!! [Re: WO23Coronet] #1475398
08/02/13 02:43 PM
08/02/13 02:43 PM
nielsville, minn.
Q
Q
nielsville, minn.
Pure Lazyness. Less mods to the carb, don't have to boost reference the fuel pump and it cost next to nothing, (for me anyway). My biggest worry was a backfire through the intake tract, so far it hasn't been an issue. My gaskets showed up today too.
I ordered them from Jegs and the person taking my order is a memeber here on Moparts. Forgive me but I can't remember his handle but his extension at Jegs is #277.
If the motor survives I'll refabricate the intake tract moving the carb over and lower to fit under the hood.Dave
Re: Boost is GOOD!!! [Re: quickd100] #1475399
08/03/13 12:22 AM
08/03/13 12:22 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
One more question: How is the timing set up?
Mo' Farts
Re: Boost is GOOD!!! [Re: Grizzly] #1475400
08/03/13 07:48 AM
08/03/13 07:48 AM
nielsville, minn.
Q
Q
nielsville, minn.
On the last pull it was locked at 20 degrees BTC, there is no advance. I'll be fiddling with timing when my 110 octane shows up, the pull was made on 91. Dave
