Strange lighting problem #1475284
07/28/13 03:04 PM
07/28/13 03:04 PM
dark side of the moon
Dougsmopars Offline OP
My 68 Super bee has a strange lighting problem. When you turn on the head lights to parking position all the side markers light up. When you turn the head lights on the front side markers go out. Car has all new wiring harness under hood and new head light harness. No cut or spliced wires. All plugs are pluged in. Is there any difference between 68 and 69 head light switch? I didn't build this car i bought it done. The wire harness are aftermarket but i don't know what brand.
Re: Strange lighting problem [Re: Dougsmopars] #1475285
07/28/13 03:06 PM
07/28/13 03:06 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You are losing or missing a ground.
Re: Strange lighting problem [Re: NITROUSN] #1475286
07/28/13 03:09 PM
07/28/13 03:09 PM
Where? Side markers are grounded to fender and do light up in park position. Go out with headlights
Re: Strange lighting problem [Re: Dougsmopars] #1475287
07/28/13 03:16 PM
07/28/13 03:16 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Did you verify you are losing power at the side maker wire with a test light or voltmeter? What are the park lights doing?
Re: Strange lighting problem [Re: NITROUSN] #1475288
07/28/13 03:19 PM
07/28/13 03:19 PM
Yes i lose power at front side markers when headlights come on. All the other parking lights work fine.
Re: Strange lighting problem [Re: Dougsmopars] #1475289
07/28/13 03:33 PM
07/28/13 03:33 PM
Castlegar, BC, Canada
That AMC Guy Offline
Sounds like something might be wrong with your new harness. On a '68, the side markers should all come on in either headlight switch position. However, the parking lights in the front bumper will ONLY illuminate in the "Park" position. The parking lights turn off when the headlights are turned on.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Strange lighting problem [Re: That AMC Guy] #1475290
07/28/13 03:45 PM
07/28/13 03:45 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That's what I was thinking. The front marker and park circuits are reversed. Most likely at the panel light connector. The green with a tracer is the front side marker circuit and it is shared with the black rear tail circuit at the panel switch. Here is a diagram.
Re: Strange lighting problem [Re: NITROUSN] #1475291
07/28/13 03:52 PM
07/28/13 03:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
They also could be switched at the bulkhead. Terminals U and Z need to be verified on both sides of the bulkhead. The Park should be black with a yellow tracer terminal location U. Side marker is dark green with a tracer terminal location Z.
Re: Strange lighting problem [Re: NITROUSN] #1475292
07/28/13 03:57 PM
07/28/13 03:57 PM
Thanks. I'll check the bulk head conector and see if new harness is correct.
