where can i get 3.91 bore specific head gaskets? #1475200
07/28/13 10:57 AM
07/28/13 10:57 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
i need fire ring bore specific head gaskets for a 3.91" bore..
does anyone have a part number or source to get these..
I am hoping to not have to go custom order.. but all the parts suppliers only have the one size fits all gasket with a fire ring of 4.179"
thanks
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: where can i get 3.91 bore specific head gaskets? [Re: cheapstreetdustr] #1475201
07/28/13 08:51 PM
07/28/13 08:51 PM
nothing?
[image][/image]
Re: where can i get 3.91 bore specific head gaskets? [Re: cheapstreetdustr] #1475202
07/28/13 08:54 PM
07/28/13 08:54 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Cometic will make any size and thickness you need
Re: where can i get 3.91 bore specific head gaskets? [Re: DJVCuda] #1475203
07/28/13 09:15 PM
07/28/13 09:15 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
You could get a oem 360 gasket and cut out the pushrod areas. They are 4.020.
School of Automotive Machinists Racing
Re: where can i get 3.91 bore specific head gaskets? [Re: cheapstreetdustr] #1475204
07/28/13 09:35 PM
07/28/13 09:35 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Felpro 26179PT or 540SD either should work for you.
