Transmission 727 #1475154
07/28/13 01:08 AM
07/28/13 01:08 AM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
How many quarts of tranny fluid should I have on hand after dropping the pan?
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: Transmission 727 [Re: chagjr] #1475155
07/28/13 01:40 AM
07/28/13 01:40 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
6 to 8, may not need them all but 6-8 usually covers it
Re: Transmission 727 [Re: TJP] #1475156
07/28/13 05:04 AM
07/28/13 05:04 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
If you are lucky and have a drain plug on your converter its always a good idea to drain that as well if your looking for a fluid change.
Of course that would require a bit more new fluid.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Transmission 727 [Re: hp383] #1475157
07/28/13 11:33 AM
07/28/13 11:33 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Seems I read 19 pints in a manual. That is with the converter. I think it was Chilton. A lot of folks don't like Chilton, but the capacities should be correct.
I have mechanical Aptitude.
I can screw up anything.
