sb rocker arm choices? #1474955
07/27/13 05:24 PM
07/27/13 05:24 PM
PA
maxwedge1 Offline OP
PA
installed "budget" aluminum roller tips several years ago.
not a whole lot of miles on motor but
just had my second and last adjuster backing out incident.
any mid range price options? I havent really paid attention to aftermarket for quite awhile. dont need H sharp level stuff.
Re: sb rocker arm choices? [Re: maxwedge1] #1474956
07/27/13 06:13 PM
07/27/13 06:13 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
What's the budget you have in mind?
Sometimes the Comp Cams stuff turns up on-line...that's what I'm running on my 360 motor (older 1420-16 part). Hughes has some of their own stuff out there, mid-300s price wise I think.
You could always look for an old set of the iron stuff...the original 273 is what I'm talking about (did they ever come on stock 340s???? no idea...).
Re: sb rocker arm choices? [Re: maxwedge1] #1474957
07/27/13 10:09 PM
07/27/13 10:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If it's not pulling the threads out you likely just need to put a little more umpf on tightening the lock nut!
