904 Fluid Flow Direction #1474825
07/27/13 03:41 PM
07/27/13 03:41 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
On the 904 transmission, which one of the lines would be the in flow? The reason I need to know is that want to still use my radiator as a first cooler then flow through an external cooler and I need to get out of the second cooler to the in flow of the tranny. I don't want to reverse that flow, external cooler to radiator to tranny. Thx
Re: 904 Fluid Flow Direction [Re: tee-john] #1474826
07/27/13 04:07 PM
07/27/13 04:07 PM
Locomotion Offline
Locomotion  Offline
The fluid is pumped out of the trans through the front fitting and the one near the tailshaft is the return line.
Re: 904 Fluid Flow Direction [Re: Locomotion] #1474827
07/27/13 08:20 PM
07/27/13 08:20 PM
United States
tee-john Offline OP
tee-john  Offline OP
United States
Thanks man !!
Re: 904 Fluid Flow Direction [Re: tee-john] #1474828
07/27/13 08:47 PM
07/27/13 08:47 PM
SE PA
Yellow Fever Offline
SE PA
Here's a list of a lot of trans lines: http://mopar1.us/cooler.html
